Question about Electrolux EW1200i Front Load Washer / Dryer
Re EW1200i : drum keeps filling with water
The drum keeps filling with water on each cycle unless you manually turn the dial on to the next part of the cycle. Is this something i could fix?
    Sergeant:
  • 236 Answers
Is it overfilling? if so you have a problem with the pressure side of the system and it would need cleaning out.
Posted on Jun 02, 2007
Our Miele DW just keeps going through cycles constantly and will not shut off on its own. It has gone all day. When we turned the dial manually to "OFF", the water keeps filling until it overflows the...
hi,
sounds like a faulty electronic unit as i have seen this before where the unit continously fills with water.
you will probably need a service call to repair the unit unless you are happy to fix it yourselves. have a chat with Miele directly as they are very helpful
Hope this helps.
Jun 20, 2010 | Miele 24 in. G865 Built-in Dishwasher
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Dec 03, 2017 | Whirlpool Washing Machines
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Ew1200i washing machine problem
my washing machine is doing the same. try adding water in manually via the dispenser drawer. see it this helps, it should then advance to the next stage. you'll have to repeat when it requires water. i'm currently fault finding myself to see what the next solution should be.
Sep 05, 2008 | Electrolux EW1200i Front Load Washer /...
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Cycle never finishes.
we have an issue with one of three things
on the sides of the lid the hinges are bolted to the lid with 2 screws on each side
ferify that the secres are tight
if so then you have a lid switch that needs to be replaced or the water pressure switch in the console is bad
Apr 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Electrolux EW1200i Front Load Washer / Dryer Logo
165 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
