Question about Kenmore 62602 Electric Dryer
Have kenmore dryer 110.86982100 does not heat changed put in new heating element and thermofuse still no heat
    Sergeant:
    Champion:
  • 262 Answers
Check and see if you have 220 volts to the dryer using a volt/ohm meter start at the dryer and work your way back following the circuit back to the fuse/breaker boxuntil you find 220 volts
Posted on Jan 10, 2009
Will not heat
it is either the heating element or thermofuse either way you will need to pull the front panel off. The screws are inside the dryers door frame, the pry up on the top it will pop up, disconnect dryer door switch lift top lid to a 90 degrees. the element is backside right looks like a spring, visually inspect, the thermofuse looks like a resistor that has two clips you can pull the clips off and tape them together and if you get heat then you will need a new one. Hope this helped tim
Sep 25, 2010 | GE Profile Harmony DPGT750EC Electric...
Blowing thermofuse on heating element
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Replace the thermostat also...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Kenmore Dryers
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Blowing air no heat open up dryer at the bottom on the heating element there is a burnt looks like a small relay that be the problem for no heat
This problem is usually a blown thermofuse. Whirlpool Dryers usually have two thermostats or thermofuses on the heating element case. Unplug Dryer, remove one wire from the thermostat, and with an electrical tester you need to test for continuity or resistance between the two terminals on each thermostat. If you have no continuity on either thermostat, order new ones, they usually will only sell as a set. If their is any burned wiring you have to cut out the burned section and put on new wiring terminals. 99% of the time this is caused by a venting restriction, so make sure your vent is clean and not smashed or restricted, otherwise this problem will reoccurr. If your thermostats have continuity, test for continuity across your heating element terminals. If this doesn't take care of it let me know and I will walk you through other tests
Dec 10, 2009 | Whirlpool Dryers
Dryer starts but wont heat
There are 2 main cause for problem;
1) thermofuse may be fault or
2) you have bad heating element.
Check if you have continuity between 2 connectors on thermofuse; a black disc usually found at the back of the dryer. If it is okey, check the heater.
It's got to be one of these.
Oct 11, 2009 | Kenmore Dryers
We have a Kenmore Gas dryer it runs but it doesnt get hot.. any ideas what it could be?
The heating element is most likely burned out. Try ordering a new heating element for your dryer and calling a repairman to put the new heating element in.
Jul 15, 2009 | Kenmore Dryers
Need to change heating element on my kenmore dryer
they are pretty simple to change out.the heating element should be easy to access and once you get the old one out you simply put the new one in in its place. depending on the machine the heating element should be in the back wich means you have to take the top off the dryer to access it and then you will see what you need to do from there,its only held in but 2 or 3 screws.
Jan 08, 2009 | Kenmore 63942 Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Dryer thermofuse blown again
Probably restricted air flow caused by lint build up. Clean out dryer and all vent pipes, check damper outside and see if it opens. After you clean out everything run dryer on aif fluff/no heat cycle and see if there is good air flow outside. If it is electric it could be that the heating element is burned out and shorting out against the frame. This can cause overheating.
May 12, 2008 | Dryers
Dryer runs but won't heat up
Is the fuse bown.or is the circuit breaker tripped?
if the fuse is blown or the circuit breaker tripped .the dryer might tumble but not heat.
Dec 28, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 62602 Electric Dryer Logo
144 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
