Question about Epson Stylus Color 440 InkJet Printer
Epson 440 won't print
Printer has been sitting unused for about 3 months. Just bought new cartridges, tried the head cleaning utility a few times. The nozzle check utility only prints out a couple tiny lines for the print pattern. Does this mean the print head is clogged / how do i clean it easily, without taking the printer apart
    President:
  • 8,637 Answers
The ink dried up in the print head. A printer should be used at least every two weeks to keep from drying up the ink. You may have to replace the print head or have it serviced.
This is not much help. Bud
Posted on Jan 25, 2009
Vertical lines when printing. Have genuine Epson cartridges installed and most are brand new. Have done a print head alignment and cleaned the nozzles.
You have a clogged print head. If repeated running of the head cleaning routine does not work, you can take a Q-tip and dip it in warm or hot water and gently rub it across the print head. You should see ink on the Q-tip. Do this a couple times until it appears that more ink is flowing then try the head cleaning routine again. This is a common problem when inkjets sit unused for awhile.
Mar 10, 2011 | Epson R1900 Printer
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
I can't get my black ink to print.
Could be the ink dried up. Unusual but happens sometimes. If you shake it does it sound like liquid in it?
If you recently replaced the cartridge, did you remember to take the tape off? (I know, sounds silly, but sometimes it happens.)
In the software, does it register that there's a blank ink cartridge installed?
Just a couple of ideas to get you going. Respond back and I'll work more with you.
Apr 07, 2009 | Epson Stylus Multifunction Inkjet Printer/...
There are stripes through the whole page of what I'm printing
Hi, its the print heads are clogged up, couple of things to try, head cleaning would be the first option, right click on your printer status program ie on the bottom right of the screen the small icon, and you should find maintenance or head cleaning, try doing this a few times, print something out see if any change, if still no success, change the ink cartridge, if still no success last try would be http://www.supermediastore.com/cleaning-cartridge.html its a head cleaning cartridge to try and clean the blocked print head, if none of the above work you would be better replacing the printer as epson charges £75 + vat to repair any printer, the last time i tried to buy print heads at trade they were about £48+vat & delivery and is really a nightmare to fit with epson,most new epson printers seem to only last about 15 months on average but its the amount of money you can save through using compatible ink, as we only sell epson printers ourselfs and this happens with 99% of returned printers..
Happy New Year
John
Dec 31, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Unused printer
Hi, the print heads are clogged up usually caused by leaving a ink cartridge in the printer when not using it, ie over time, but epson have this problem alot.
you could try this http://www.supermediastore.com/cleaning-cartridge.html
ie if head cleaning dont work,,
this should fix it, otherwise its $48 + vat was the cheapest i found for new print heads or £75 for epson to fix it.
i would replace printer ie if cartridge dont work,,
Happy New Year
John
Dec 14, 2007 | Epson Stylus Photo R1800 InkJet Printer
No ink is coming from my ink cartridge?????
Hi, I find this problem occurs when the Print Head dries out. You can buy special cleaning fluid for this. Just google search for "epson 440 print head clean" You can clean the print head yourself with some warm water on a lint free cloth but this is quite messy.
Aug 25, 2007 | Epson Stylus Color 440 InkJet Printer
Epson Stylus Color 440 InkJet Printer Logo
312 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
