Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson won't turn on. Cleaned filter and still nothing
Is the motor blown? I just plugged it in and it made a quick power on noise and then nothing. Now, nothing...
  • SB UK Jan 18, 2009
    I've just had the same problem with my DC07. Changed the fuse and then tried to switch it on. It made a brief power up sound which then rapidly faded. It sounds like a motor problem. Would like any advice on fixing this.
    Ta
  • 10,865 Answers
Sounds like the belt broke. Bad news regarding all Dyson's. You can't replace just the belt your self. You have to purchase a new belt assembly which includes the gears. And it wont be cheap. I would call it a design flaw but i am sure that dyson calls it a profit scheme.
Posted on Mar 29, 2009
My Dyson V6 started suction and motor pulsated instead of staying on. Filter cleaned - nothing blocking wand....help
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 07, 2017 | Dyson Vacuums
My dyson d14 animal keeps cutting in and out. When it's on, the hole above where the filter is, keeps making a loud suction noise and it won't clean up hair and dirt.
Vacuum Cleaners require AIr-Flow. Your machine is not getting any air-flow. The noise you hear is a valve opening up to prevent your machine from overheating and burning out the motor.
You probably have an obstruction somewhere in the machine. Dysons are kind of known for that in the vacuum cleaner world.
Check all air channels and clean them out. If that fixes the problem you still might have issues that caused it to clog up.
I posted the part second because it takes 24 hours to complete it.
Be sure you wash your Washable Pre-filter. It needs to dry for 24 hours. Never put it back in the machine wet.
Once it is completely dry reinstall the pre-filter and your machine should be back to normal operating functions.
Let me know f this helps.
Dec 31, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
I HAD MY DC17 VAC FOR 3 YRS NOW NO PROBLEMS AT ALL, I REGULARLY CLEAN THE FILTER LIKE IT SAYS BUT LATELY I'VE NOTICE THAT THERE SEEMS TO BE A LOT MORE COLLECTION ON THE TOP OF THE FILTER WHEN I'M DONE...
The vac is over heating. First, you should try a new filter. Also, keep in mind that after cleaning the filter, make sure that it fully dries. Using a wet or damp filter clogs it quickly. Second, turn the vac upside down and make sure that the roller is fully cleaned and free of hairs and strings. Afterwards, with the vac upside down, quickly power on and make sure that the roller spins and listen carefully for noise at the roller. There may be something stuck inside. If it doesn't spin, verify that the belt has not slipped off or broken.
Good luck.
Sep 27, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
On turning on different noise then noticed smell of burning then just stopped working and no power since. DC 07 Dyson.
Unfortunately your motor had burnt up..most times this is due to not cleaning or replacing the filters...the filters get dirty and the motor gets no airflow to cool it....very common on dyson vacs
Feb 07, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson won't even turn on...
Hi there, it sounds as though the motor may have failed.
If you would like to arrange a repair, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC07 All Floors Bagless Upright...
Dyson dc14 died, no power after burning smrll
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson animal
Is the noise a loud screaming or a grinding/vibration? The screaming is an air flow problem and you'll want to check your hoses are clear and all the seals are tight. The grinding is an issue with the roller/belt/clutch/motor/housing. From what I'm reading, both problems are common on the Dyson animal.
Sep 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
1,641 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
