Question about HP OfficeJet V40 All-In-One InkJet Printer
Line running through my copies
I copy photos alot and the pictures are extremely clear except for a line running through them. How can I fix this?
  • 39 Answers
Go to the printer program and look around it should have a way to clean & align print heads try that and let us know how it does
Posted on Jan 06, 2009
5740 hp officejet printer streaks on scan or copy
The glass is smudged or dirty or the scanner bar may have dirt on it. Cheaper to just replace the machine.
Aug 19, 2016 | HP DeskJet 5740 InkJet Photo Printer
How to install iphoto pictures on sandisk extreme
Hi Martk
Not sure what you mean by install - do you mean copy ?
Insert your Sandisk and make sure you cn see it on the desktop.Open iPhoto and resixe the window so that you can see the sandisk icon.Select the picturs you want (by dawing boxes around thewm - they highlight with yellow lines as a rule when they are selected) then drag one of the selected pictures on to the sandisk. You should get a green blob showing how many pictures you selected and a + sign.That's it. y0ou can drag photos out of the iphot window as if they were ardinartu files in a folder. They do not get moved but they copy automatically to wherever you drag them - even on to the desktop.
Dec 15, 2012 | Apple iMac G5 Desktop
Sandisk Extreme 4 Gig card. 151 photos on card, copied to computer. Took 140 more photos, viewed them on the camera many times. Tried to copy to computer, no photos are present in finder window and no...
try out in another computer whether the pics r there or not if there copy paste them in a separate folder in computer last time did u cut n paste or copy n paste try recalling if u have done the cut n pasting process the data will not be there in memory card
Sep 23, 2010 | SanDisk Extreme III 4GB Secure Digital...
The screen viewer looks clear before the picture, but after the picture is taken the viewer displays a very lined and grainy photo. When copied to the computer the lines and grains are copied. The camera...
A couple of thoughts:-
1) Check the resolution the camera is set to, it may, for some reason have been set to the lowest photo resolution.
2) Have a look on the Pentax web site, follow links to Support and or Downloads. There may be a firmware upgrade for your camera. There also may be a forum on the website where someone has had this problem before and resolved it.
Apr 01, 2010 | Pentax Optio M50 Digital Camera
I have alot of photos in my pc and wanted to put this 2gb card and get them on there
put the microSD into a micro SD adapter and plug the adapter into the SD slot on your PC the folder will open and you can drag photos from your photo folder into the SD folder
Oct 01, 2009 | PNY 2GB microSD Memory Card
Photo card
there is a lock on the top corner of the card......slide the lock to the opposite direction and it will work fine.
May 30, 2008 | HP PSC 2210 All-In-One InkJet Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
No copies
You may have a bad drum ground or a bad charge cnnection.Try cleaning all contacts on the units and where they connect on the rear of the frame.
Oct 17, 2007 | Sharp AL 1631 Copier
HP OfficeJet V40 All-In-One InkJet Printer Logo
Ben Johnson
