Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony TV - No picture
Gradually the picture has been taking longer and longer to come on. Now it does not come on at all. But there is still sound.
    Novelist:
    Champion:
  • 236 Answers
If the picture slowly fades on, the you may have a weak picture tube or a loose solder connection in the filiament circuit. If the picture flashes on then you may have a problem with the High Voltage/Horizontal circuit. This type of problem could be caused by a loose solder connection on the horizontal driver transformer. There are several other problems that could cause this type of problem. Stargazer
Posted on Jun 02, 2007
SOURCE:
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Green tint on screen especially with dvds. picture also cuts out for a few minutes every hour or so on our sony kds-50a2020
Usually in this set if screen gradually changes to something other than black and white the optical light engine is the problem---major part.
Google the model number with "problems" or "light engine" to learn more.
Aug 28, 2012 | Sony KDS-50A2020 Television
When I turn on my sony kp-46wt520 tv the sound comes on for several then the red light blinks 5 times, and the tv shuts off. this problem happened gradually, it used to come on after several attempts but...
I am sorry to hear regarding the trouble. A 5 blink error code indicates a white balance error. This can have many causes such as incorrectly adjusted screen voltages on the CRT's, a bad CRT drive IC, or a bad picture tube/CRT.More often, it is due to bad driver Ic's The Ic's are labeled MCZ3001D(B) and they should be found in the middle of the deflection board.If you call a technician, the estimate cost would be around $250 - $350.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 30, 2011 | Sony KP-46WT520 46" Rear Projection...
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony tv model KV32S42 picture taking forever to come in
Speaking as a retired SONY dealer, the short answer is probably yes. There are some repairs an authorized SONY repair center can do but if the tube is displaying a soft picture, it may not be wise to spend a couple hundred on repairs when a new medium quality TV is three hundred to five hundred for a SONY. I applaud your devotion to a set that has served you well.
Dec 05, 2009 | Televison & Video
Sony Trinitron TV now taking around 5 minutes for picture to appear (sound comes on instantly) Is it worth repair or should I cut losses and replace set?
How old is the TV?
Sony Trinitron sounds like it may be from the 1980's?
Some TV engineers can use a piece of equipment to do a "tube boost" but this is sometimes risky and can completely ruin the tube, but it's a risk you would have to take.
If the TV is over 15 years old, and has been used regularly, (like 4 hours every day or more) it seems likely that the tube has reached the end of life.
TV cathode ray tubes are like light bulbs...they do not last forever!
Nov 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture
This can be a scan amplifier failure, failure in the high side of the main power supply, the picture tube may no longer be having emission, or the heater supply to the picture tube may not be working. There are many parts inside the set that can cause failures.
You will have to take the set in for proper shop service by an experienced TV tech.
Jerry G.
Jun 27, 2008 | Sony KV-36XBR450 36" TV
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Dec 07, 2007 | Sony KP-53HS10 TV
SONY KP57WV600-Turns Blue
yes ,it sounds like screen adjustment or focus block, should be around $200- $325 to repair.
Sep 08, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
