Laptop won't turn on
I have an advent 7302 - a while ago it needed to be plugged in all the time to work. the charger stopped working and i bought a new one last august and all was fine. at xmas my son said the charged had gone again, however, i have checked it on something else and it's not the charger so i bought a new battery. we have plugged it in today but it still won't turn on. please help as my 16 year son is so depressed without the laptop. Many thanks, Leigh
  • tillymint11 Jan 06, 2009
    Thanks for such a quick answer. If it's not the battery and it is the socket on the motherboard is that easy to fix?
    thanks
    Leigh
    Is a motherboard easy to fix?
    Thanks
    Leigh
    Master:
  • 416 Answers
It can be lose laptop power inlet too.
There are several ways to check it.
1. Try to use laptop with only charger and see if it is working
2. Try to use the charger you bought with similar laptop, but it might be hard to check.
3. As was suggested before, try to borrow the known working adapter and use it with/without battery. And try to put the power inlet more tight to see if it will help.
But if it is Dell it most probably defective power adapter socket on motherboard
Good Luck
Posted on Jan 06, 2009
  • 10,515 Answers
A/C adaptor is died :((
And the battery ran ntil drained................
Change he a/c adaptor :) and its all fixed....
Sometimes, due to oercharging, this might happen...
Thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, charge the new battery for at least 4 hours without turning on the laptop. Even with the laptop off, there should be some indication (a light) that the laptop is receiving AC power and is charging the battery. If there is no such light, then we have a hardware issue.
Since you have checked the charger (presumably powering another device) and the battery is new (but could still be a suspect), that would leave us with the charging circuitry/internal regulator of the Advent 7302. This could be as simple as a cold solder problem, detached connection, cut foil/trace on the board or a defective power jack. Whatever it is, the laptop has to be opened up for a look and see. With this in mind, it is therefore important to establish/eliminate the possibility that the charger and/or the battery as the culprit. On the:
  • battery, charge as above prescribed;
  • on the charger, use a voltmeter to verify voltage output.
Good luck and Thank you for using FixYa.
    Genius:
  • 3,422 Answers
HI,
Please remove the battery and then try connecting it with the adaptor and turn on your laptop.If it works then the issue is with the battery and you need to replace it.Incase it doesn't turn on then the issue is with *********** board.You can try reinserting the ram and then try to turn it on.If it doesn't trun on then you will have to get this repaired.There are no home remedies.
    Scholar:
  • 86 Answers
Hi!
Based on experience... this may sound that you have a busted battery before and now it could be the ac adapter, or worst... the motherboard.
Easisest way to isolate problem is to get or borrow a known working ac adapter compatible with your system.
If it works, well and good since ac adapter is the only thing that needs replacement, but if not, it is really the motherboard unfortunately.
  • 19,396 Answers
Try connecting laptop to charger without putting the battery in. If charger is good, and laptop still has no power, then it is likely a defective power adapter socket on laptop motherboard.
  • Ginko
    Ginko Jan 06, 2009
    If the AC adapter is tested good, then the laptop must start even without the battery inside.
    Try first connecting the laptop to the power adapter, without having the battery inside, if it is still dead (no lights or sign of power at all), then there is a fault.
    If you have no power at all the fault is either an internal short, or a losen contact (broken solder joint) on the AC charger socket on motherboard.
    This can be fixed at a local repair shop for a not too expensive charge. If the technician is good he will solder back the socket rather than replacing the motherboard.
    Note : if you have lights coming on , then it is not the above, in that case is faulty motherboard, faulty RAM, or another faulty device, and the faulty part mnust be replaced.
  • Ginko
    Ginko Jan 06, 2009
    About the easy fix, no , it is not easy to fix, to access the motherboard you need to take apart the laptop completely, and the soldering must be done in the proper way.
    You need a technician to do the job.
Won't turn on?
stop leaving it plugged in all night it will over charge ur battery if doin so
Sep 07, 2012 | HEWLETT-PACKARD Computers & Internet
I have a advent 7302 laptop the usb ports do not reconise anything pluged into them and when i plug a device in the mouse pad locks the cursa
Try and re-install the USB drivers for the Mainboard, Any problems with external devices in USB ports could be due to a lack of power (or low power ) on the ports. I hope this helps point you in the right direction.
Jan 22, 2012 | Advent Computers & Internet
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
I bought a Dell Inspiron 1318 about 3 years ago, new. About a year ago my battery stopped taking a charge. I just decided I needed to buy another battery online from BattPros.com. I followed the...
Hi
Check this
When your shut down your computer and plug your the charger in your laptop that time Orange lite is showing on. if no showing then its problem to your laptop
Jun 05, 2011 | Dell Inspiron 1318 Laptop Computer PC...
Advent laptop, been on holiday for a week, it has not been used in that time. It won't power up with the charger plugged in or not, the power lights are also off. Charger is broke but pc world techguys...
Well, if the chargers don't work that leaves a problem with the power connector on the motherboard. If the socket was or is loose it could be causing a short on the board. The cost of the motherboard will most likely rule out any thought of replacing that. If you have a working charger try removing the battery and with the power disconnected hold the power button down for 60 sec. Then plug the charger in and try to turn the PC on. I've seen this work before and it makes no sense that it does but you can try it. The only other problem I can think of that might cause this symptom if the lid cutoff switch is stuck in the down position and over riding the power switch.
Oct 12, 2009 | Advent Netbook
Advent Netbook 4489
IT sounds like you need to replace your battery. If your laptop (notebook) is working properly while plugged in with Ac power we know it is not your power supply.
I would visit the manufacturer's website for replacement batteries. One complaint I have read about over and over on these particular systems is that the battery life is very poor.
Sep 17, 2009 | Advent Netbook
Intergrated webcam on Advent 9215 Windows Vista Hoem Premium.
Hi, I've the same problem , My LAP TOP ADVENT 9215 webcam not working , what can i do ? please .....
Jul 08, 2008 | Computers & Internet
Display driver r300
Try K-Lite Mega Codecs pack Its A Freeware.
Click Here
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
