Question about LG WM-2277HW Front Load Washer
Need repair man for the LG WM0642H washer. I live in northern NJ. Washer sounds like a helicopter at 18 months.
  • csgrasso Jan 08, 2009
    I also live in Northern NJ and am having a problem with massive vibrations from my brand new LG dryer.  It is installed on the main floor of my ranch in a laundry room.
  • 640 Answers
Right here on fixya.com...go to the service directory and shop around for your area,,,your spin surport basket most likely leak through the back tub seal..
Posted on Jan 10, 2009
My 5 year old washer makes a squeaking sound
If the washer is making a loud noise while the drum turns, the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer should it be the bearing. This work will need a technically minded person to accomplish.
Jul 04, 2014 | LG WM0642H Front Load
Will not go into spin cycle ,LG appears and shuts down the washer
check the drain pump this is the most common repair made on these units, if the washer doesn't drain it will not spin, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | LG WM0642H Front Load
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
Just flashes the code
Thermistor is out of order. Printable service MANUAL
Mar 01, 2010 | LG WM0642H
LG Wash WM2487H*MA- how to turn the tub clean feature on?
I have had this problem since I bought my washer. Some days the tub clean cycle will work....most days it won't. They have replaced the main board twice and it's still broken. I've had nothing but bad luck with LG appliances. Also bought a lemon fridge that took 4 repairman visits to fix. I will not buy another LG anything!!
Jan 17, 2010 | LG WM2487H Front Load Washer
LG WM0642H Sounds like a helicopter durning Spin
It sounds like the machine is not balancing correctly. My guess is that if you operate the machine empty (no clothes inside) that it will operate fine. If so, then the machine is not balancing correctly.
Normally an error code should come up if there is a balance issue (UE error). If this code is not coming up then the machine thinks it is balanced when it really isn't. This means that either the hall sensor is sending out incorrect data or the main board is not interpreting the data correctly. A technician should be able to ohm out the hall sensor to see if it needs replaced or the main board.
Hope this helps, please rate my solution.
Jan 06, 2009 | LG WM-2277HW Front Load Washer
LG Wm0642H door seal problem
I replaced the seal on my mother-in-laws LG washer last month. The seal has 2 bands. One that the attaches to the drum, and one that attaches to the front of the washer. The hardest part about replacing the seal, is gaining access to the seal. Once you gain access to the seal, it can be a little tricky getting the bands back on, because you have limited area to work. There is no special tool or tricks to get it back on, just persistance.
Jul 28, 2008 | LG WM0642H
LG WM-2277HW Front Load Washer Logo
62 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
