Question about Kenmore 80012 Microwave Oven
Kenmore microwave won't heat
My daughter thought she set the timer, but instead the microwave ran for 10 mins. with nothing in it. Now it won't heat. Can it be repaired? Is it worth repairing or should I just replace it?
  • Anonymous Jan 23, 2009
    I did the exact same thing and it had the exact same result. Any help would be greatly appreciated.
    I have a Kenmore 721.80012
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
    How old is it or how long have you had it?
  • 209 Answers
SOURCE: microwave won't come on
I am a recently retired appliance engineer of 20 years, i am reluctant to help with microwaves because of the dangers, the store electric even when unplugged, but it sound just like an internal fuse, these are special quick blow types, can be bought from most electronic high store shops, and replacements must be exact match, if a replacement blows there is another fault and don't recommend self repair work with safety and remove the plug first etc oh the fuse is just inside following the mains wire in, and normally on a small circuit board if i have helped please rate me
Posted on Sep 09, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp mdl R-1870 convection microwave runs for 1 min
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: overheated microwave
Hopefully the magnetron thermal cutout or thermostat protected the magnetron from destruction!
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 26, 2008
SOURCE: Kenmore Microwave won't heat.
your problem might be more than a fuse chech the magnetron
Posted on Oct 31, 2008
beltronic205
  • 1474 Answers
SOURCE: I accidentally ran my Kenmore microwave Model No
Depends could be thermal cut out gone more likely magnatron....Perhaps you could claim home insurance...Accidental damage...please leave feedback.
Posted on Apr 07, 2010
Kenmore 62463 / 721.62463201 Stainless Steel 1200 Watts Microwave. My daughter used it as a timer for reading and set it to cook for 30 minutes with nothing in it. It turns on but is loud and no longer...
You probably fried the magnetron(it actually makes the microwaves that do the cooking). I bet you will find the magnet is broken(from excessive heat). There should be a diagnostic guide sheet somewhere inside the housing(due to running production changes,this is a guide for the pros to test the power supply,magnetron,etc with an ohmmeter to determine which is defective.
Sep 18, 2013 | Kenmore 62463 721.62463201 Stainless Steel...
Husband thought he set the timer but actually ran the over for 35 min. This was really hot and now looks dead. No displays, nothing.
Yes, you are probably right... he killed it... :-(
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 16, 2010 | Jenn-Air JMV8208AAS Microwave Oven
I THOUGHT I SET THE TIMER-YET I HAD SET THE
Without food for the microwaves to be absorbed by, the magnetron (heating device) would have most likely overheated. There is a thermal overload switch (safety device) that acts like a fuse and turns everything off if overheating occurs like that. You would need someone that could take the microwave down, disassemble and check to see if the 'fuse' is bad or the magnetron is bad, they can both be checked with an ohmmeter. If you need to hire someone to do this, it may cost you more than the cost of a new unit if the magnetron is the item that has failed.
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I accidentally ran my Kenmore microwave Model No 401.80083700 with nothing in it, for 20 minutes (thought I'd put the timer on)now it has just stopped working. No power coming on at all. Can this be...
Apr 07, 2010 | Microwave Ovens
Kenmore 401.8008700 ran 10 minutes thought I'd set on timer
It could be the fuse. You will also need to check the condition and alignment of the door switches.
Eric
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
Microwave will not heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
wsw
Oct 09, 2008 | GE JVM1640 Microwave Oven
Sep 29, 2008 | Kenmore 62702 Microwave Oven
Kenmore 80012 Microwave Oven Logo
313 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
