Question about Protron V33239 Television
Speakers I need to find a place to buy the brace for the speakers that are attached to the side of the 32" tv. It is attached to each side by 3 screws.
0 characters
1 Points
I'm have a vizio TV model gv47l fhdtv10a,I need
call any tv place they have new installation kits thatyou can buy
May 17, 2013 | Flat Panel Televisions
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
I need to replace my table top stand for mySony 32 inch Model # KDL 32S3000, can you guide me in the right direction
The instructions are in your USER MANUAL found at the following link:
In general though you should lay the tv screen side down on something VERY soft and flat like a bed so that the screen doesn't get scratched at all.
Then find the 3 philips head screws that hold the base to the tv. They should have replaced into the proper holes in the back of the tv when the base was removed initially. Unscrew and remove them and then place the base into position on the tv.
Once the base is fitted into position, insert and tighten the 3 screws again. The tv can now be lifted vertical again and placed where desired. Be sure not to press too hard on the actual LCD screen part when handling.
Good luck and post back how you make out.
Jan 23, 2011 | Flat Panel Televisions
I have lost the screws to my 47SLV80 LG TV and I need to find out the screw size to replace, does any one have any info on what size I need to buy? I never used the tv, brand new.
most all of the new tv's have the same screw its a machine fine thread #12 (for small tv -32 in) and #8 for larger I bought some at my local hardware store 3$
Dec 14, 2010 | LG 47SL80 LCD TV
How can i fix the blown speaker
If it has headphone jack, try to see if you get both channel OK. I would use the powered PC speakers attach to the Audio Line out RCA jacks than the cheap buit-in speakers, just make sure that you set the audio set up for the Audio Line out to be variable so you can use the remote to adjust the volume, and just set the PC volme to about mid point instead.
Nov 11, 2009 | Protron PLTV-32 Television
Vibrates when shound turned up, tried different sound modes, it is the bass that is a problem deep voices etc
Rattling speakers on a LG TV is fixed by placing a small square rubber between the speakers and the chassis.
Of course the speakers will need to be replaced too
May 25, 2009 | LG 32LG30 32 in. LCD HDTV
Norcent 32
Is the sound coming from the TV speakers or from an attached component?
If from the Component, use the TV speakers if it has one. If the TV speakers stay on then you have an audio component issue.
Mar 02, 2009 | Norcent Technologies LT-3222 32 in. LCD...
I have a 32 inch proton and would like to moutn it on the wall. The brackets that i find in stores requires the tv to have screw holes spaced along the back of the tv. Mine only has screw holes where the... I bought a shelf anchor and a 5/8" x 12" x 36" shelf for around $30 including screws, mounted the shelf on the wall and placed my LCD TV on the shelf. City Mill and Ace Hardware aezd4csells them.
Dec 03, 2008 | Protron PLTV-32 Television
Need a disassembly guide for lnr328w
You can buy the servive manual from the same Web site. I have one and I am working on my TV now. Here is the Short list:
1) Disconnect all cables and power. Place the TV face down on a soft surface. (Blanket, Pad, etc.)
2) Remove the 4 screws in the base if it is installed, and then slide the base off.
3) Remove the 8 or 9 screws around the edge of the back cover.
4) The cover "snaps into place" so you will need to carefully pry the back cover off and set it aside.
5) Disconnect all cables on the Power Board and remove the 6 screws that attach it.
Assembly is just the reverse of the above.
Good Luck!
Nov 17, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
How to Remove the Base
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Protron V33239 Television Logo
Top Protron Flat Panel Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Protron Flat Panel Television Expert? Answer questions, earn points and help others
