Question about Lexmark X75 All-In-One InkJet Printer
Prints only color ink nothing in black
Out of the blue my X75 when I print a document only prints color text and omits all black text. New black cartridge installed last week.
  • 1 more comment
  • majorlane Jan 09, 2009
    There was no sticker on the black cartridge. Today - once again - out of the blue the printer began printing both colors again.
  • Juanita Vega
    Juanita Vega May 11, 2010
    so now it is working?
  • Juanita Vega
    did you make sure that the sticker was off the ink cartridge?alot of people forget to take it off.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Computers & Internet
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Ink cartridge
you may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even refilled.you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Jan 20, 2009 | Lexmark X75 All-In-One InkJet Printer
Can't get my Pixma MP500 to print with black ink
check MS Word settings in 2007 is in "Word options" Display, printing option
In 2003 is in Tools, Options, in View tab check peint and layout options
Jan 17, 2009 | Canon Pixma MP500 All-In-One InkJet...
Word 2003 not printing text, but prints everything when a clip art is added
I solved it! Aint no stopping me now!!!
This may not be a permanent solution, but it is one that will remedy the problem if you are caught in a bind!
Change the color of your document to the next color lighter than black but dark enough to print as black. Other colors do print.
Perhaps it is a problem with the black ink and/or cartridge.
My 6 page document printing normal with the exception that I changed it from the default black setting to the next lighter black color.
Now who will pay me for this tip? No charge, just kidding!
Sep 24, 2008 | Microsoft Office 2003 Pro (269-07387) for...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Lexmark X75 printing difficulties
if the black was empty you would notice the difference in the pictures as well, but if the word print is black, it wont print in colour it's supposed to print what you see.
Sep 10, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
