Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
My SRX200 consistently disconnects from the internet.
I unplug the router from the power source and it resets, I am having to do this more often. I am using it with cable.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
the wall plug type power supply (made in China) may be likely bad.
This actually is a switch mode power supply very unlike the old and usual linear power supplies.
It is common the capacitors used in this supply are under rated and do not last very long. Then funny and intermittent stuff can happen.
The problem usually seen with dim LED lights on the unit, limited range and intermittent operation.
Try to find a replacement power supply with perhaps higher current rating.
Good luck
Posted on Jan 10, 2009
Im connected to my wifi internet in the office but i cannot open the internet . the brand of router is cisco WRT54G2VI, SERIAL #CSVO1HC21627, MAC.ADD 002369214852, ARROW SYMBOL UP DOWN 45103834, please...
If your computer shows you the little yellow triangle (limited connectivity) then you might have to reset the source of your internet, the modem if you can access it, by unplugging the power for 30 seconds. then reset your router by unplugging the power for 30 seconds so it can aquire a new IP address if you get the internet through dynamic settings. The router could also have a bad ethernet internet port. If you can connect to the router wirelessly and tried resetting it and if you can get internet being directly hooked up to the modem or source of internet such as a wall outlet...then your router may be bad.....if it is a Belkin...then it was junk to begin with.
Aug 28, 2013 | Cisco Computers & Internet
I am unable to get wireless internet access. By directly pluging the modem into my laptop the internet works but the srx200 wirless doesn't connect. I was stold by our internet provider that I may...
Hello nanpw,
To reset your router to factory, take a paper clip and press the reset button. Hold it for about 30 seconds or until the lights on the router flash. open a web browser and type 192.168.1.1 username is (blank) password is admin then run the wireless setup utility, after your laptop is connected its always a good idea to include security.
Aug 15, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
My road runner internet works fine, and for years my linksys srx200 wireless has worked great, just yesterday my wireless connection is excellent as always but our laptops all say cannot connect to the...
Hi
If you have an internet connection using the ethernet cable but not on the wireless and there is an orange light blinking.. Try to reset the router by pressing the reset button located on the back or on the location were you can twist the stand for the router. press it for about 10secs and that will return the router on a factory settings. before u reset the router make sure to acces the configuration for the internet settings of your isp provider. if the orange light still there, try to download the latest firmware of your router on linksys site and that should fix the problem
Jun 10, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Problem with the Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) wireless light does not come on
If the wireless light on the router is not coming ON that is a sign of something is wrong with the router settings or with the router itself.
First thing that you can do here to correct the problem is to do a reset on the router, To reset the router using a paper clip or pen press and hold the reset button of the router for 10 seconds while power is ON and then once done let go the reset button and unplug replug the power of the riuter then check now is the wireless light is back ON , if the light for wireless is back on you can now continue an reconfigure the router.
But after the reset and still nto able to bring the wireless light back ON your next step here is to do a firmware upgrade on the router. You can follow these step by step procedure from this link , just click HERE and then follow the steps to upgrade the firmware of the router.
May 23, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Connectivity issues with my srx200 wireless router
First take the ethernet cable one end should fixed with ur PC/laptop and other end connected to ur modem.finally configure the access page .
Apr 30, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
My LinkSys Wireless-G SRX200 randomly reboot,
Check if directly connecting the computer to the modem works. If it does not try to reset the router and flashing the firmware. If you have a copy of the original firmware you may use that. If it does not work you may have a bad router.
Sep 27, 2009 | Linksys 4-port Wirelss Router W/srx200...
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Forgot Password
If it's the password to login to the adminitration page(GUI) of the router your pertaining to, then the only way to solve it is to reset the router to factory settings(Press and Hold the reset button on the router for 30 seconds, release the reset button and wait for the power LED to go solid). Now if it's the WEP or WPA key or encrytion key for you wireless connection, Open the router's Admin page using another computer that is connected to the router or hardwire the same computer to any of the 4 Ethernet(LAN) port on the baack of the router. Open Internet Explorer and enter the router's IP address on the address bar(by default it's 192.168.1.1) then you'll get a pop up windows asking for the router's by default there is no username and the password is "admin".
Oct 14, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Oct 27, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
121 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
