Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
My Kenmore Elite HE4t (110.45087402) washer will not go into spin cycle. All of the water drains correctly and during the spin cycle the drum turns slowly. No error codes. Everything else seems fine.
    New Friend:
Im having the same problem as the person above with the same code showing what do I do.
Posted on Nov 29, 2014
  • 15,935 Answers
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • chatMoon Dec 27, 2010
    What does that mean. I have a Kenmore Elite SmartWash Quiet Pak 9 HE4t front load washer. I have same problem and I do get a F06 error code. Is this something we can manage to fix at home? Or is this time to dump the washer? I hope not.. :(
What does the S2 code stand for on a he4t washer
Posted on Oct 07, 2012
How to repair HE4t with HF code?
HE4T had problem on control board when early time version. Later they modified control board and find new version should fix your problem.
Apr 24, 2014 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T won't stop on the Spin Cycle. Stays
Replaced the relays with the 16Amp rated ones from Digitel.
Aug 15, 2009 | Kenmore Elite 45986 Front Load Washer
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,791 people viewed this question
Sal De
fordexpert
Robert Rankin
