Question about LG WM-2277HW Front Load Washer
LG WM0642H Sounds like a helicopter durning Spin
This thing is 18 months old and sounds like is going to jump out the window during spin. Is there a reasonable fix for this or is it time to replace it and what model shoud I buy... No more LG for Harry
  • Anonymous Jan 11, 2009
    I just bought one and had it delivered yesterday.  Washed the 1st load today, and thought that someone was driving through our house when it went to the spin cycle.  Other than that, I am extremely happy with it......  Any help is appreciated, or it is going back.
    Sniper:
  • 88 Answers
It sounds like the machine is not balancing correctly. My guess is that if you operate the machine empty (no clothes inside) that it will operate fine. If so, then the machine is not balancing correctly.
Normally an error code should come up if there is a balance issue (UE error). If this code is not coming up then the machine thinks it is balanced when it really isn't. This means that either the hall sensor is sending out incorrect data or the main board is not interpreting the data correctly. A technician should be able to ohm out the hall sensor to see if it needs replaced or the main board.
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
Durning the spin cycle, the washer is jumping all over the place
One or more of the suspension springs have failed. Here is a link to the spring.
Take a look at this video.
Oct 15, 2012 | Whirlpool ATW4475VQ Washer
Washer sounds like it has rocks in it during spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Whirlpool GHW9100L Front Load Washer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
When my washer is on the last spin it is very loud, almost like it needs a muffler
You didn't say what model washer you have, but it sounds like you have a bad spin bearing. When bearing is bad it can be very noisey during spin, like a helicopter taking off. This means your washer needs a bearing and seals overhaul. This is generally a very expensive repair unless your washer is under some kind of warranty. The spin water seal has more than likely been slowly leaking, causing bearing to go bad.
Jan 31, 2010 | Washing Machines
NOISY DURING SPIN CYCLE
If this sound starts slow and gets faster till its helicopter sounding you probly have a verry worn spot on the drive belt when that spot goes around the pully it will thump the faster ti spins the more frequent the sound If you tilt the washer back you should be able to see the belt to examine it if this the problem
replace the belt
Hope this helps
please leave feedback
Nov 27, 2009 | Maytag Legacy Series Top Load Washer
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
Need repair man for the LG WM0642H washer. I live in northern NJ. Washer sounds like a helicopter at 18 months.
right here on fixya.com...go to the service directory and shop around for your area,,,your spin surport basket most likely leak through the back tub seal..
Jan 06, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
251 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
