Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
WAHER BEGAN MAKING A LOUD RATCHETING NOISE BETWEEN RINSE DRAIN AND SPIN CYCLES. WATER PUMPS OUT BUT AGITATOR AND MOVER RATCHET AROUND SLOWLY WITH NOISE BUT DOES NOT SPIN. I'VE CHECKED COUPLER---LOOKS FINE. MOTOR AND PUMP FINE--- REMOVED AGITATOR AND EXAMINED REPAIR KIT (DOG EARS) SLIGHTLY WORN WITH SOME PLASTIC SHAVING BUT STILL GRIP RIDGED RING THEY FIT INSIDE OF. NEXT STEP TO CHECK THE BASKET DRIVE BLOCK BUT NOT SURE HOW TO ACCESS. MOVING IN THE RIGHT DIRECTION? HELP APPRECIATED CANNOT AFFORD NEW ONE OR REPAIRMAN.
  • 113 Answers
Really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Posted on Jan 08, 2009
The washer did not drain and won't forward to rinse. After removing all the wet clothes and scooping out the water I set it at rinse and it began to fill but I wasn't able to forward it to spin though it...
Check the lid switch first. It will not drain or spin if the switch is not closed. If the switch is ok check the pump for a foreign object or frozen bearing. If dropping the hose allows water to siphon out the blockage may be a small object.
Eric
Jul 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ8543JQ0, the washer fills will water on all cycles but does not do a wash, drain or spin.
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise during spin
You have something stuck in the drain pump.
Remove the pump and clear the debris.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer will not spin
my washer will not finish spin and reins cycles please HELP ME
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate Care II will not spin and makes a loud noise, I did get it to drain the water.
The usual culprit is the motor-transmission coupler. This is located between the motor and the transmission. You need to remove the pump and then the motor to access it.
Oct 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
724 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
