Question about Frigidaire GLTR1670A Front Load Washer
Metal noise under tumbler
I've done this before--left coins in my pocket. When under warranty they came out to repair but now I'm on my own nd obiously something has been loose ans has gone thru the holes during wshing. Can I fix this myself?
  • 1,294 Answers
You can try to locate the stuff by removing the bose right under your tub; of course by disconnecting all the wall electrics. Access to this is by removing the back panel.
Posted on Jun 05, 2007
Samsung washer WF328AAW/XAA metal pieces in hose?
Could be a number of things. Either something foreign was left in a pocket (Coins are the most common object) and has come out in the wash. The coin rattles around and falls in between the tubs through the gap in the front gasket. When this happens, the coin can hit the bracket which holds the heater element in place and tears it off. This causes a lot of damage. Most Samsung have plastic outer bowls and often, the tub will be split and a leak will start from underneath. Lastly, it could be the drum main shaft and spider assembly. This is what holds the spin tub into the machine. If this fails, bits of metal will come off. Usually seen as bits of corroded aluminium that get stuck in the pump and hoses. When this happens, the tub usually goes loose and the machine makes a horrible grinding and banging noise when spinning. I would say that if this has happened , its time for a new machine.
Sep 10, 2014 | Samsung WF328AAW Front Load Washer
Bosche axxis washer spin cycle ticking noise
Assuming everything else is working normally, I would still suspect there is an object that is getting stuck between the rotating drum and the outer housing. Maybe not coins, but something longer, like a pocket comb or the wire inserts used in some garments. It is easy to take the top off of the unit, and this might help to isolate the noise better. Early spin is usually a bit unbalanced, so it is possible it could also be something really simple like a hose clamp that has sagged enough to be contacting something else, and it only shows up when the machine is bouncing a bit.
Mar 16, 2013 | Bosch Washing Machines
We hear a rubbing-grinding noise during wash cycle.
your machine is a FAV6800A or FAV9800A correct?
This could be coins or other debris under the tumblers.
If you want to DIY the fix see this post you need the Service Manual nad a number 20 TORX driver to remove the tumblers. SM left that info out.
Google this for a link to the SM 5th post in.
""Neptune TL Washer FAV6800AWW"" I can help you at that DIY forum.
Google this
""FAV6800A/FAV9800A Outer Tub bearing replacement""
I helped a couple forum members get thru Outer Tub bearing rebuild. One of the forum members took some pics where you will view the Tumblers removed. It
Feb 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
This happens during the washing cycle,very loud noise when the two wheels are turning the load.I'am afraid this is going to a big fix. please help
Do you think you have some coins or other debris that has gotten under the tumblers?
If so I would remove the tumblers and inspect fro coins/debris.
If you do a Spin Only Cycle is the machine quiet?
Are you going to DIY if so you need the Service Manual.
Join this forum then download the SM 16022808 Maytag Top Load Neptune Washer Service Manual
The Service Manual doesn't call out the TORX driver size to remove the tumblers it's a #20 Torx hardware...............Rich
Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washer that won't drain. I took the front panel off and detached the hose from the pump and there were several coins in there. I removed the coins, reattached everything and...
For the FAV6800A or FAV9800A tumbler removal.
The Service manual has the procedure starting on page 37 for the tumbler removal.
It’s not difficult to remove the manual doesn’t call out the Torx driver size required for tumbler removal. You will need a number 20 Torx driver to remove the Torx screw for tumbler removal. I would get a long Number 20 Torx driver for this. See page 37 of the Service Manual for tumbler removal. Looks worse than it is.
The Service Manual for reference. Sears Parts Direct for reference.
When I did a recent Outer Tub Bearing replacement I found $1.78 in coins after removing the wash basket. Gotta check those pockets....:)
I have a post around somewhere of my diy Sump Screen I put in my FAV6800AW to protect the drain pump impeller from coins and other stuff from breaking the impeller or causing clogs. I'll look for the post or repost the pic's.........D*ick
Sep 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Dryer squealing
probably some was in a pocket and is now jammed in the seal you will need to take the whole cas(sheet metal ) off of the unit to access the tumbler seal
Jan 06, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Maytag neptune frontload washer code nd
Yes maam, I sympathize with the situation. The "nd" code on the Neptune is usually a pump related issue. Check the drain line for kinks first, and then the pump will have to be checked. No matter how diligent we are, inevitably hard objects like pins, coins, etc., make it into the washer. Remove the hoses from the pump and using a flashlight, look into the suction port and check for any obstructions. Also check the pump impeller for any broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hard objects that make it to the pump can damage the impeller blades on the pump. Sorry for your trouble and I hope this helped. Best wishes.
Aug 27, 2009 | Maytag MAH8700A Front Load Washer
Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
Apr 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
We have a penny stuck under the white spinning things.
Hello pinkygirll,
The Service manual has the procedure starting on page 37 for the tumbler removal, take a look and see if you feel comfortable to give it a try. If you are handy or someone you know has basic mech. skill sets you can perform. You, I and many others need to check those pockets. Here is the service manual link.
The manual doesn’t call out the torx driver size required for tumbler removal. I just removed my tumbler cap and measured, it’s a #20 torx driver. If you call a repair service in make sure you have your Model# and Serial# number ready to pass along to them. You mentioned”” There is a penny stuck and the washer stops with water in it after it tries to spin.”” The tumblers do not rotate in spin cycle only the wash cycle. If you do a Spin Only cycle with no clothes in the wash basket do you hear the grinding noise? Good Luck.
Mar 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Coin stuck under tumbler on Duet front load washer
If you dont have screws on your tumbling vanes, you can take a very small screw driver and lightly lift the vain enough for the coins to slide out.
Oct 18, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Frigidaire GLTR1670A Front Load Washer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
