Question about Nintendo DS Lite Console
How do you remove and open the ds card slot?
My DS card slot has bent pins and won't read any games, so I was wondering how to get it disconnected and open so I can try to fix it or connect a new one.
  • cwahl Jan 07, 2009
    No, not the card, the card slot.  It won't read any game cards because the pins are bent, so I need to take it out and fix/replace it if I want to use it.
    Problem Solver:
  • 10 Answers
Use needle nose plyers to JENTLY bend back into place
Posted on May 21, 2009
You push down your DS card to get it out ,and to put it in you take the card you want and push it in slot 1.
Posted on Jan 07, 2009
Sometimes in DS card inserted, no working
The ds lite an ds have cartridge slot problems its common
either a pin is bent or the plating on the cartridge slot has come off so copper is showing or is green
Needs a replacement slot
Happy to give a free quote
dsdoc
Aug 09, 2011 | Nintendo DS Lite Console
My ds slot does not show up on my choose games even though i put the games in it says 'no ds card inserted" please help me i have my ds but only the gba slot works
There is probably one or more bent pins inside the top slot (SLOT 1). Remove the battery by removing the battery cover on the bottom (held ny a screw). Shine a small torch into SLOT 1 and look inside to see if any of the pins are bent differently to the rest of the pins. If any pins are bent they can be bent back to their correct positions by using a suitable small tool such as a precision screwdriver. If a pin is actually broken then the complete slot will need to be replaced.
If it is not a bent or broken pin, there may be some other type of blockage inside SLOT 1.
If there is nothing wrong with the pins and there is no blockage inside the slot, then there may be a dry joint where the slot is soldered to the PCB inside the DS. This kind of fault will require the DS to be opened with a special tri-wing screwdriver and the use of a multimeter to check all the connections. If you have soldering experience (and tools) then you can try re-soldering the connections.
Be advised that opening the DS is much easier than putting it back together again!
Feb 14, 2011 | Nintendo DS Lite Console
My Ds Lite isn't recognizing the ds game/ says there is no ds card inserted. Please help.
check the connector where you plug the game it maybe dirty or some pins broken
Nov 04, 2010 | Nintendo DS Lite Console
DS not reading game
This is usually due to either bent or dirty pins in the card slot, look inside and see if any pins are bent, if they are a new card slot is needed.
Hope this helps
Jul 19, 2010 | Nintendo DS Lite Console
Help, My son's DS wont read the cards all of a sudden. The kids began to blow them because they were intermittently reading them is this the problem. I brought a brand new game to see if it was the old...
Sounds to me like one or more of the Pins in the Card slot is bent or Broken. take a good look in there with a flash light. May just need a good Cleaning with some pipe cleaners. if the pins are Bent or broken you can Open it up and fix your self but this is something that you need to be a little more advanced to do. But Fixable.
Jan 18, 2010 | Nintendo DS Lite Console
Nintendo DS lite Slot 1 bended pins
You can do it yourself by removing the casing, check out this youtube video. http://www.youtube.com/watch?v=vRzTgfo2PsM
Please rate my responce
Jun 03, 2009 | Nintendo DS Lite Console
On the ds lite the picture said there is no ds card inserted when there is
This happens a lot!
Two possible options. Take the card out and blow on the card slots to remove any dust etc.
or
Have a look down into the DS slot to see if any of the little copper pins have bent out of place (this happens sometimes from putting in and out the card quickly) if they are bent you may have to replace the card reader.
Apr 11, 2009 | Nintendo DS Lite Console
My ds lite will not read any games
You may have a bent pin on the game slot. Try inserting a game several times rapidly in and out. Look at your game cartridges and see if one of the contacts is damaged in the same place on all of the cartridges.
If this does not solve the issue, you will need to get your console repaired. Either the repair shop will replace all of the electronics or resolder a new game slot on your existing board.
May 25, 2008 | Nintendo DS Lite Console
Nintendo ds lite won't read card
had this problem, i looked into where the game goes and one of the little metal teeth was bent, so i took a long toothpick and gently pushed it back over now it works fine. Be careful that you dont break it off though.
Feb 08, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
511 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
