Question about Mitsubishi VS-50605 50" Rear Projection Television
VS-50605 I have a Mitsubishi VS-50605 television. While moving the front screen blew off onto the highway. I need to obtain another front screen, where can I get one? Thanks
Vertical sync- top of picture pulls to right on intermitently. Fly back?
Posted on Jan 14, 2008
    Genius:
  • 1,153 Answers
Sears Service center
Posted on Sep 20, 2007
Mitsubishi VS-50605 - no vertical control until it warms up and it is now starting to flash to a black screen
Howdy,
CHECK AND REPLCE C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR) BOTH ARE ON THE SIGNAL PCB.
Good Luck, big IRISH.
Dec 29, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
May 28, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Very dark picture...mitsubishi wd 62725
try pulling the front panel off and cleaning the bulbs inside and the mirrors and all screen protecters and magnifier, just becarefull not too scratch them
May 10, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Repair help
Good Day, limao247;
Your TV may fluid on the PCB's. Remove the speaker grill, the small panel and look closely for fluid on the boards towards the front. Always unplug the TV for your SAFETY. If you find fluid clean board with acetone. Good Luck, big IRISH.
Aug 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Cleaning the Inside
pull front speaker grill it snaps on take 5 or 6 screws out just under screen lift screen by sides straight up entire screen will come off exposing mirror
Nov 19, 2007 | Mitsubishi VS-50605 50" Rear Projection...
How to take off protection screen of a Mitsubishi VS-50605 50 in. Rear Projection
Usually have to pull the speaker grill off (friction fit), there will be some screws under the bottom edge of the screen, if there are wires you may have to unhook them, sometimes the plugs are behind a pannel that gets unscrewed from the front. The frame will come apart to drop the new screens in.
Jul 14, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 Screen
might measure the opening and buy a piece of plexiglass, wont look quite as good, but cheaper than a new one and usually available at glass shop.
Jul 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Vs-50605 Mitsubishi
Infrared pcb is located inside mirror cavity mounted to CRT support frame.Follow lead to signal PCB--is it plugged in,to the correct location??----Then suspect bad infrared detector PCB.Or,possible bad signal PCB.
May 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
