Question about D-Link Air DWL 520 802.11b (DWL-520) Wireless Adapter
Connection problem i install my wireless airlink 802.11g on my desktop and it wont connect to the internet. nothing will pull up. cannot find server. it work fine for 2 weeks. but it disconnect and wont come back.
    Scholar:
  • 108 Answers
You may be a victim of heat creep. This is when a module works itself loose from constant heating and cooling.
If you've recently moved the machine that could loosen it also.
Try this.
Power down PC > Unplug from wall > Unseat the card and reinstall > while you got the machine open, if it is dusty, clean it up a little. Helps the machine out a little.
Posted on Jan 16, 2009
Airlink AR430W wireless router stopped working
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Nov 23, 2009 | Airlink AR430W Wireless Router
Airlink ar430w not giving a network address to netgear wpn111
Try assigning the IP address manually. To do so go to Network Connections, right click on the wireless connection and click on Properties, select Internet Protocol TCP/IP and click on Properties again. Select use the following IP address and type the address of the same range as of your Router's IP. In case you do not know the range try 192.168.1.5 or 172.16.1.5 with the subnet mask as 255.255.255.0 for both, and when you use the IP as 192.168.1.5 use the default gateway as 192.168.1.1 and for 172.16.1.5 use the default gateway as 172.16.1.1 Also select the lower option as "Use following DNS Server address" and for 192.168.1.5 use 192.168.1.1 and for 172.168.1.5 use 172.16.1.1 .Click on Ok. Click on Ok again and now check for the connectivity.
Jul 08, 2009 | Airlink AR430W Wireless Router
Cant connect to the internet on my lap top
first thing is to identify the wireless settings of the router,you need to identify the wireless name (SSID), channel and the encryption you are getting from the airlink router. Next is to make sure that the wireless computer has enabled wireless signal/ or the wireless is on.
after that, you may connecting wirelessly to the computer, right click wireless connection and go to view available wireless networks, try to connect -input the encryption key from you wireless router or password and hit connect.
Jun 28, 2009 | Airlink AR430W Wireless Router
In my home office I am using an airlink 101 802.11g wireless usb 2.0 adapter to connect with my airlink 101 super g wireless router on my main computer. Everything has worked well, but today my office...
Hi.
This method will hard reset the wireless drivers back to default settings.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Jun 17, 2009 | Computers & Internet
Have an airlink card bus
If you have access to change the wireless routers channel do that. Log onto your router from the wired connection probably 192.168.x.1 (x is your subnet, find this by going to run>type cmd>hit enter>type ipconfig>hit enter the gateway IP should be your router
type that ip in a browser i.e. http://192.168.x.1 and log in go to wireless settings and find the channel option. usually you'll want to keep it at 1,6, or 11
(if your wireless utility doesn't show channels) go to your wireless pc and install netstumbler > install it > click the scan button and you should see all of access points around you. choose a channel that is used the least between 1, 6 and 11 and save that as your new channel on the router, as you are probably getting a lot of interference.
second try using the built in windows utility instead of the airlink one
also
update network drivers
update router firmware
don't sit around large metal objects :)
Jun 10, 2009 | Airlink (AWLH4130) 802.11g/b Wireless...
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Wireless not picking up
at first your card its detected or not if not then replace it if yes then go to the right click to my computer there option is there manage in that device management is there in that your card has yellow mark in the other option just double click on it then re-installed the driver option is there put the card and the cd in the computer then you get it
Jan 26, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
D-Link Air DWL 520 802.11b (DWL-520) Wireless Adapter Logo
357 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
