Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Won't work in 480i or 1080i mode
My tv is around 2 years old and it will not work in 480i or 1080i mode on HD. However, it works perfect in 480p mode with native off. Let me explain the symptons a little better. When I set it on 480i I get a "no signal" message. When I set it on 1080i mode the picture looks like a 3D movie without the glasses and the picture is skewed a little. The problem seems to have started when the power went off one day. I have Directv with the HD100 converter. I use and HDMI cable but get the same results using composite, etc. I have a newer LCD HDTV which works perfect in all modes with this same Directv HD receiver.
    Sergeant:
  • 279 Answers
I think Bluenadas is right that it's the digital board. To be sure, I would suggest opening it up and looking for any bad capacitors. Those are small round things sticking out of the board. If they are bulging or leaking anywhere, that's your culprit. Replace the board they are on and you should be fine. You can purchase boards for this here: http://tigerdirect.partsearch.com/GetModel.aspx?MfgName=Samsung&BrandName=Samsung&ModelNumber=HCP4752W&page=3 However, unless there is something visually obvious, like the bad capacitors, it's going to be difficult to be 100% certain that the digital board is to blame without replacing it.
Posted on Aug 30, 2007
  • 203 Answers
Have you tried a different input like a DVD to ensure the issue is with the TV? If the issue is indeed the TV then replacement of the video card (Or digital board) is warranted. If there is a separate board with all of the video inputs on it that would be the video board. If the main board in the unit has the video connectors on it, that is the digital board.
Posted on Jun 08, 2007
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
Feb 16, 2011 | Polaroid TLA-04011C 40 in. LCD TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
I dont know if my lcd tv supports 720i, 1080i, or 1080p
Sorry. It does not. 480i and/or 480p.
http://www.generalmanual.com/Televisions/Sanyo-CLT1554-STEREO-LCD-TV-EDTV-Monitor.htm
Picture Resolution: 1024 x 768 (XGA);NTSC (480i) EDTV (480p)
Dec 24, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
No HD 1080i
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
May 21, 2007 | Mitsubishi WS-73411 73" Rear Projection...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Jerry Greenberg
Jerry Greenberg
