Question about Epson Stylus CX4600 All-In-One InkJet Printer
Magenta does not print
I tried cleaning the Print head under maintenence,and the Magenta still does not print, and it shows a full ink cartridge. What can I do to fix this? All the other colors print on the page except the Magenta. Thanks Jeff
  • Jeff Curtis May 28, 2007
    Thanks for your help. I fixed the problem. I am an idiot. I forgot to take the tape where it says "Pull here" lol sorry.
    Jeff
    Genius:
  • 2,985 Answers
Can you find the bits and piece to make a orubt head clearing pump like this illustration? If you can take the cartridsge out fit the pump and suck out any ink in the chamger. Then empty the pumt and fill with Windex or propanol alcohol dilute with distilled water to 10%[or windex] and pump this through back and forth untill it shoes clear- put the cart back and see what happens Also download this utility www.ssclg.com set it up for your printer Also take a look at www.fixyourownprinter.com
Posted on May 27, 2007
  • john ash
    john ash May 28, 2007
    We all do it from time to time.
    glad to be of assistance
Replace pixma printhead
Print heads on this model run about $80 on ebay. Your best bet is to first replace the magenta cartridge even though it may appear to still have ink in it. After that, go into the maintenance menu and run a full cleaning cycle several times. This may clear your clogged print head.
Apr 18, 2014 | Canon Pixma MG8120 InkJet Printer
Photos are coming out Orange
Clean your print head under the ink maintenance / cleaning. Then test print. All your colors should pass this test. Your magenta is not complete.
Nov 21, 2013 | Brother DCPJ315W AllInOne Inkjet Printer
Magenta ink won't print though cyan and yellow print okay after refilling for the first time. Also, everytime I remove cartridge (color) the print head is full of ink blot. (is this normal?) I have tried...
Sorry for the delay in my answer. No you do not need to remove the ink from the cartridge itself. Soak remove the cartridge and soak it as is. You will get a huge colour change in the water but it will not use any more than 0.1ml of ink
regards GM
Apr 21, 2011 | Canon PIXMA iP2200 InkJet Photo Printer
Replaced T0603 magenta ink with brand new cartridge. Ink levels show its FULL. But when do nozzle print check, no magenta line will print. Trying to pring something with red clip art and can't get the...
Depending on when you last used your printer it may take a few head cleans before the ink prints. Print a nozzle check after each clean (uses minimal ink).
Also be aware each clean depletes your other carts as well.
Jan 09, 2011 | Epson Stylus C88 InkJet Photo Printer
Ink clog between magenta cartridge and print head.
print head may be burned out try cleaning it then tap the cartridge and try a test page to see if it prints, if it still does not work try a new cartridge if that does not work then the print head is burned out, it may be under warranty you can go to www.hp.com and input your model and follow the trouble shooting guide and if you can't fix it you can register for free live chat help with the problem and it may be under warranty, many printers are having problems with this color cartridge drying up and causing problems not only hp but other brands as well. I suspect the pigment drys up but am not sure about it.
Feb 11, 2010 | HP OfficeJet Pro K8600 Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
RX680 shows ink is full but will not print lt mag, mag, or cyan
usually the problem occurs when the ink is running low and a big print job is being done. by then, the printer runs out of ink and starts sucking air into the tubes. If several cleanings dont help, try leaving it off for a couple days, turn it back on, try another cleaning and see what happens. if it still does not work, most likely the printhead will need to be cleaned which will cost about $40 - $65 if cartridges are need too.
If you are you using generic ink, that can cause the problem too.
Feb 10, 2009 | Epson Stylus Photo RX680 Printer
Brother DCP-120C Printer - Does not print black, Black and magenta cartridges renewed with new Brother cartridges. Black ink level reset OK but not magenta. Have tried automatic head cleaning but still no...
have you recently had a paper jam. somtimes pieces of paper can become trapped under the print head which restricts the printing. if there is and its been there for a while the print head may need to be wiped/cleaned( a bit tricky) then a couple more print head cleans.
Nov 04, 2008 | Office Equipment & Supplies
Epson Stylus CX4600 All-In-One InkJet Printer Logo
380 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
