Question about Medion md40298 Notebook
Medion Pocket PC and the GPS has disappeared.
Have gone to use today and the GPS has disappeared from the screen?
I am unable to access all I have is the start screen
  • taiworaheem Jan 14, 2009
    Am facing the same problem, i think i wuld have love not to regret buying the system, i mean base on this little problem people were scared from getting one
I have a i-mate jama Pocket PC, yesterday it turn off due to low battery. Today I recharge it but it hang on align screen message..... I have tried several times but all in vain...
you should reset your phone.reset code is 1234.after that "align screen" shows
tap the screen at target for few moment untill align screen does not go.it takes several attemp.after align screen disappear time & date setting option appear.set it.after this window will reinstalling.it takes few minutes.after this phone will be started.
Sep 26, 2009 | i-mate JAM Pocket PC
I need a manual to work the medion pocket pc model mdpna100
get connected to www pdf-search-engine.com/medion-pdf.html. here they will give you neccessary support with medion manual easy to read and follow lebelled diagrams to guid you. another contact is www ciao/co.uk
Mar 18, 2009 | GPS
Just got an old medion pocket pc pna gps nav system but all the new roads in my area are not on the maps.how do i install updates for new road layouts?
I have a medion PNA 100 MD 95025 HAVE LOST MY SAT NAVIGATION THAT USED TO BE ON THIS MODEL HOW CAN I GET IT BACK AND I HAVE TRYED TO DISC I GOT WITH IT BUT IT DOES NOT LET ME DOWN LOAD IT PLUS I HAVE A MAC AND NO GO THREW MY PC CAN YOU GIVE ME SOME ADVICE
Jun 26, 2008 | Medion GPS
Will not fire up a gps signal
Most GPS systems require a first time boot-up where they scan all registered satellites to determine where in the world they are and what satellites to concentrate their navigational efforts on. Try charging the GPS up entirely, and then doing a hard reset of the system (either by navigating to the hard reset in software or by pressing the tiny reset button usually located on GPS units), and then taking the system out under the open sky and letting it run for half an hour or so, making sure it is running in navigation mode (as opposed to setup or media mode). Once it locks properly onto a small subset of satellites, it should not have much difficulty.
If you continue having problems, check to be certain you are running the latest software on the device which can make a big difference. The latest software for the 520 is here:
http://www.navman.com/Navman/Templates/standardcontent____4407.aspx
Good luck...
Nov 21, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
Medion MD-96032
Are you able to see the screen as if just the back lighting is turned off?
Nov 12, 2007 | Medion MD-40954 Notebook
My backroud
On the rx3715, the background on the Today screen can be changed from Settings>Today. From there various themes can be selected and used. Also, if there is another picture I want to use as my background, I can browse and select it from the same screen.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
Medion md40298 Notebook Logo
60 people viewed this question
Top Medion Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
