Question about NEC Electra Professional ETW-16DC-2
I have a NEC ETW 16DC-2 phone that does not ring with calls
The phone does not ring with incoming or intercom calls. I know the phone can be programmed somehow but I dont have my manual.
  • audrey349 Jan 12, 2009
    The phone still does not ring and the speaker does not work either. :( Sorry. I appreciate your efforts. I'm beginning to think it may be a bad phone.
  • drowl87 Apr 03, 2009
    I also have the same phone system (Electra Professional Level II), but I can't figure out how to change which phones ring with outside calls and which ones don't. The intercom and everything works like it should, I just want to make one particular phone ring when we get calls from outside the office.
    Problem Solver:
  • 16 Answers
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Posted on Jan 12, 2009
  • Eric Conrad Jan 13, 2009
    If indeed you have no sound when you press the speaker button, it may well just be a bad phone. It is possible that the speaker is simply unplugged inside the phone and with a phillips screwdriver you may just be able to fix it. Otherwise, it will likely need replaced.
yes enter program mode and change MB 4-01 for your port number. Assignment of ringing per phone.
Jun 02, 2009 | NEC ETW 16DC-1 Corded Phone
Can't find caller id function on NEC ETW-16DC-1 BUSINESS PHONES SYSTEM
You have to make sure the phone system you have has CID cards in it. What kind of card is in the Electra phone system.
Sep 08, 2008 | NEC ETW 16DC-1 Corded Phone
How to program a line to ring keysets
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Apr 08, 2008 | NEC Electra Professional ETW-16DC-2
How to activate mic phone
Feature 1 or function 1 will work
Mar 04, 2008 | NEC Electra Professional ETW-16DC-2
Internal intercom
If the person you are trying to reach is speaking to another internal extension, none of the outside lines will show in use. If their phone is not Call-Forwarded to any other extension (i.e. second extension or VM), you will get a busy.
Feb 06, 2008 | NEC Electra Professional ETW-16DC-2
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
Jan 28, 2008 | NEC Electra Professional ETW-16DC-2
NEC Electra Professional ETW-16DC-2 Logo
3,637 people viewed this question
Top NEC Lands Phones Experts
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
