Question about GE Energy Star WCVH6260F Front Load Washer
Water authority turned off water & washer not working now
After the water authority turned off the water supply and did some work in the neighborhood my washer is not working - It turns on and humms.
Any suggestions?
  • daynagene Jan 06, 2009
    thank you - I'll try that
  • 1,543 Answers
Disturbing the water supply caused sediment to flow in and block the inlet screen(s) on your washer. Take the supply hoses off and look inside the part they screwed off of to find screens. Remove the screens and clean. Reinstall. Check that there are not filter style hose washers in either end of the supply hoses which may need to be cleaned out.
Posted on Jan 06, 2009
Washer does not fill
Widgett,
I understand that you are having trouble with water entering into your washer. Here are a couple of things to check out.
1) The water supply is possibly not adequate in the area where the washer is located. Check another faucet in the house. Wait until water supply and pressure increase.
2) The water supply faucets are not completely open. Fully open hot and cold faucets.
3) The water is being used elsewhere in the house. Water pressure must be at least 30 psi. Avoid running water elsewhere while washer is filling.
4) The water inlet hoses are kinked. Straighten hoses
If you are still having issues, I would suggest to contact a local authorized technician. When they come out they can take a look at the appliance up-close and determine what exactly is going on.
-Best Regards-
Jan 16, 2014 | Frigidaire GLTF2940ES Front Load Washer
Error code 7 - EcoSmart Washer - Fisher and Paykel
Hi there, what is the exact model of you washer?
Mar 22, 2008 | Washing Machines
Washer is working during spin, meaning it's still
Hi, a Kenmore washer that is not filling with water may have clogged inlet screens. Place a bucket underneath the hoses to catch any leftover water. Unplug the washer and turn off the water supply. Remove the water hoses from the back of the washer and inspect the screens inside the inlet ports. Often, these clog with sediment. Clean the screens with a small toothbrush. After cleaning, reattach the hoses and turn the water supply and power back on.
Another reason the washer might not fill is something interfering with the water pump. Check the connecting hoses on the water pump to make sure they are not clogged. With the hoses disconnected, check the water pump for obstructions.
Jun 19, 2011 | Kenmore 24722 Top Load Washer
Kenmore Washer HE 2plus my machine has an error F 20 won't do anything
The technical details of this fault code are shown in the first image below. This information is valid for most Kenmore HE2+ washers. It is likely that it will apply to your model. If the washer is not filling with any water, check the water supply faucets behind the washer to make sure that they are properly open. If you are using a floodsafe device as shown in the second image on your water supply lines, I recommend replacing this device with normal water supply hoses. The floodsafe device will not work properly on most washers. Turn off the water supply faucets and remove the supply hoses from the connection on the back of the washer. Check the inlet screens on the back of the washer for debris or deposits that could prevent the washer from filling properly. Clean the screens if necessary and carefully replace them after flushing the inlet to the water valves thoroughly with water. (Failure to properly flush the inlet area could result in debris getting past the screens and fouling the inlet water valves.) While the water supply hoses are still disconnected from the back of the washer, place the ends of the hoses in a bucket and briefly turn on the water supply faucets to check the water pressure and flow from them. If the water supply is inadequate, you may need a plumber to resolve this problem. If the washer still won't fill after checking these issues, then you could have a failure in the solenoid water fill valves for the washer. You could also have a wiring failure or a problem with the electronic control board.
If the washer is filling, your problem would likely be in the water level pressure switch or the air pressure tube between the bottom of the tub and the pressure switch. A wiring failure or control board problem could also prevent the water level from being properly detected. To access the water level pressure switch, you can unplug the washer and remove the top panel. Screws at the very back of the top panel secure it to the washer. Remove these screws and then pull the top panel slightly back and then up and off the top of the washer. The water level pressure switch is normally on the rear of the right side panel of the washer. Check the air pressure hose and wiring connections. If no problems are found, you may need to replace this part.
Jan 02, 2011 | Kenmore Washing Machines
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water is not getting hot even on highest setting
Check that the wash temperature has not been turned down accidentally. If not, then the most likely and obvious cause of this is the element has become faulty and needs replacing. This could also be caused by various other problems such as a faulty thermostat, resettable fuse links or activated over temperature detector, fused links in the power supply, faulty logic board, etc. Call a service engineer ASAP.
Oct 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washer was working fine! Moved washer to new house, and now it will run but only with hot water. put washer on Auto controll, and cold cold or warm cold setting, and it wont even turn on.
Have you tried checking your cold water supply faucet? Are you sure there is cold water running out of that faucet before you hooked up the hose? Is it possible there is a shut off on the supply valve that isn't turned on? Therefore it will not run on cold water setting? This actually happened to me once. We went away for a week and turned the water off for the hot and cold supplys. Came back to do laundry and only turned the hot one on and not the cold. Good luck!
Aug 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not turn on
Dear customer
plaese perform the following checks
There are two circumstances to get this problems ,and i had showed the two different probabilities occur this problem so go through the following
(1)Washer does not work and makes no noise :
(2)Washer does not work but it does make noise:
Please rate this,Thank u
Dec 17, 2008 | Washing Machines
I have a Maytag Model MAH8700aww washer
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Dec 12, 2008 | Maytag Washing Machines
GE Energy Star WCVH6260F Front Load Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
