Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
My new 400D with kit lens produces dark pictures. I tried everyth
My new 400D with kit lens (18-55mm) produces dark pictures even with a 430 EX speedlight and multiple adjustments like; exposure compensation; large aperture (f3.5); slow shutterspeed (1/60); high ISO.
  • 477 Answers
Take it back and get it replaced sound like your shutter Assembly went out.
Posted on Jan 22, 2009
I just purchased the Tamron 18-270 lens. When I take photos with the flash on, I get like a dark half-circle shadow either at the bottom or to the side of the photos. What could be causing this?
Lens is to long for the internal flash. Try an external one, it's position is more away from the center of the camera. Normally this should'nt happen, may be that the internal reflector of your flash is disorted.
Try to get a cheap 430 EX, more power, better light and with an radio controller usable as an unleashed flash. You'll get better pictures with flash a little bit far away from the camera angle.
Jan 25, 2011 | Cannon EOS 50D Digital Camera
What is error 99
What wide angle lens is it need f number it may be to old to work on eos 400d
Dec 27, 2009 | Canon EOS 400D Digital Camera
Dark viewfinder
Reset the camera to factory settings.
If still you have the problem, use a different se of lens.
It seems the iris is not working properly in the lens.
Try in clean the lens and the camera contacts too.
Best regards,
Jun 09, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon speedlite 430 EZ does not match with canon 400 D digital camera how to use the same flash with 400 D.
You can't. The metering systems are incompatable. You must use the EX range with the 400D, such as 430EX or 580EX (versions I or II)
Feb 25, 2009 | Canon EOS 400D Digital Camera
Dark pictures using flash
You could try increasing the exposure level (press AV+/- while rotating the selector wheel to the right) but this will increase the time the shutter is open and increase the possibility of picture blur. Only other thing to do when shooting indoors is to change to a high ISO - 1600 for instance. This reduces the time the shutter is open so working together with the first suggestion you may not notice any difference!
If still too dark, you need a faster lens - you can pickup a 50mm f/1.8 lens quite cheap - this is an excellent indoor lens as the low F number means it lets in lots of light. The fixed focal length means you will have to move around to frame the shot, but they are indispensible for indoor work and a lot cheaper than a f2.8 zoom.
Feb 07, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Taking dark pictures, any suggestion, advise on setting?
Press i think it is upwards on your little d-pad.
put the exposure up more.
May let more light in?
Jan 08, 2009 | Canon EOS-20D Digital Camera with 17-85mm...
Canon EOS 400D kit lens problem...
It would be very difficult and not recommended to take appart a lens unless you can easily spot set screws around the area that you want to remove. One thing I would try is to lightly push on the broken off edges back and forth to set them up straight in as much a circular orientation as possible. Sometimes when a piece of any ring breaks off the remaining edges are facing inward or upward depending on direction of impact that caused it, and that way they rub against the encapsulating material as the ring turns.
Aug 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Won't Work As Slave With Canon EOS 400D
Speedlites with the suffix "EZ" are never compatible with the digital EOS line-up. All models that do work are named "EX" (420, 430, 550, 580EX et al.)
Apr 03, 2008 | Canon Speedlite 540EZ TTL Flash
Canon E0S 400D locks up
is it still in warranty? send it back to cannon, there is a problem with this model doing that.
Mar 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon 400D
Use a card writer and copy your pictures to the CF card on the computer.
Jan 07, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
