Home | Barbeques Galore | Turbo Elite 4-Burner with Rear Burner 182... | STS Turbo heat problem
Barbeques Galore Turbo Elite 4-Burner with Rear Burner 182931  Grill
Problem for Barbeques Galore Turbo Elite 4-Burner with Rear Burner...
By Simi Dan on May 26, 2007
I have a Barbecues Galore STS Turbo 4 burner propane grill that doesn't regulate heat. High and Low give the same temperature on all four burners. The temp holds at 425 it won't get hotter or cooler.
The store has stood me up twice on a promised service call. They schedule a service tech and he never shows. I am very dissatified with this supposedly top-of-the-line product and with Barbecues Galore themself.
Dan B.
Same Problem
Jan 11, 2009
-   I just bought a Turbo from a Ga store that went out of business, so I won't be getting any help from the business. The first three burners have a high flame, but the fourth burner can only manage a "low". Any advice on how to adjust this?
Mary in Atlanta-   Alerice
Best Solution
posted on May 31, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Problem solved. The store FINALLY sent someone out who knows what they're doing. After about a hour of adjusting and tweaking he got it working fine. Apparently, the adjustments have to be made with the grill partially disassembled so flames can be viewed from top and bottom.
Also, it needs to be load balanced with adjusting with all burners on, then with fewer and fewer burners on.
Dan B.
Popular Solutions for Barbeques Galore Turbo Elite
Questions and Unsolved Problems for Barbeques Galore Turbo Elite
Do you recommend Barbeques Galore Turbo Elite 4-Burner with Rear Burner 182931 (LP) Grill?
Answer
Answer
can i get info on a used flat top that has a CG58 mod #? it is wired for 197-219 ac now help . i... (More)
Answer
cheapest place to purchase a neil perry t grill on the gold coast qld
Answer
can't light the ir burner. seems to "blow" itself out
Answer
Can I get a vacuum snout kit (1901463 )and a rake in tray kit for (1901114) for model # 47279 -... (More)
Answer
Looking for the plastic/metal terminal part that connects the motor to the switch. Has number 97148... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Barbeques Galore Turbo Elite...:
Top Grill and Smoker Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Grill and Smoker Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
