Question about RCA D52W23 52" HDTV CRT TV
RCA d52w23 shows pictures in triplicate:blue green and red.
Menu doesnt have convergence option
  • valeaves1969 Jan 12, 2009
    My tv has a serious bow with the red blue and green lines at the top and bottom of screen How can i find someone to repair it?
  • Anonymous Mar 02, 2009
    Sniper:
  • 62 Answers
There are several things that can cause this. There is a "light pipe" that connects from the lamp to the color wheel. If the mirrors inside have become dirty, broken, or have shifted it will cause the picture to do this. Also the color wheel itslef could be dirty or worn out. And the final culprit could be the light engine itself. You can have any in home TV tech test these out for you.
Posted on Jan 10, 2009
    Genius:
  • 1,030 Answers
Did you rember step seven .. resoldering the flyback connections
Posted on Jan 15, 2009
RCA D52W23: Only partial convergence menu. I can only access Autoconvergence, Red and Blue convergence options (not Level 1, 2, 3, etc.) in the service menu. The picture is only slightly off (i.e. green...
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2011 | RCA D52W23 52" HDTV CRT TV
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
My Zenith tv picture on the screen looks like a bowtie red green and blue are seperated on screen
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | RCA D52W23 52" HDTV CRT TV
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
A red blue and green line comes across both the top and bottom of my tv . alignment is also off
Sounds like the classic convergence option symptom. If you press menu and scroll to the set up screen see if the auto convergence feature is still listed. If its no longer there the rca repair kit called ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com will usually repair that problem. The kit contains the parts and the CD with repair instructions.
Aug 03, 2010 | RCA D52W23 52" HDTV CRT TV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Distorted picture
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 26, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Rear projection had a 3-d like picture. one red one blue and
Go to menu then setup if you do not see convergence on menu then FL231 is open replace it then do auto convergence.
Jan 02, 2009 | RCA D52W23 52" HDTV CRT TV
RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
RCA D52W23 52" HDTV CRT TV Logo
349 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
