Question about Myryad M Series MDP 500 7.1-Channel Amplifier
Pre-amp locks up
After 10 to 20 minutes of operation the pre-amp locks up, usually with a "Myrtad MDP500 Powering-up" message. At tjis point the powerr button does nothing. The only way to get around the problem is to unplug the unit. I suspect a micro-processor problem. Is their a US repair service that anyone knows of? Is a schematic available. I have not received any response from my e-mail communications to Myryad.
  • 1 more comment
  • Ronchino1964 Nov 28, 2007
    Hallo, I have the same problem whith the MDP500; last year I sent it to the repair center in Milano (Italy), and they kept it for almost three months, saing afther all that it did not showed any problem during their tests, and they sent it back to me. It worked well till one week ago, when the same problem showed up again. I don't know if I should sent it back to the Milano repair center, but it is the only one in Italy. I'm seriously thinking of changing product!
  • bobby caringal Jul 18, 2008
    I have my Myryad MDP 500, I bought last 2003. after I used it for a week the power start to turn off. I send it back to the Myryad distributor ( artech electronics) for service. after using it for another year it shows thesame problem, power suddenly turn off.
  • dor ohayon
    dor ohayon Oct 22, 2013
    Did someone fix the problem or find way does it happen?
  • 54 Answers
Check the repair dirctory at the bottom of this site
Posted on Dec 01, 2007
  • dor ohayon
    dor ohayon Oct 21, 2013
    where i can find the "repair dirctory"?
NHT sa-2 amplifier won't go into standby mode after 10 Minutes of no signal
Does the NHT sa-2 have it's own pre-amp? Because I'm wondering if the power off only works when it's own pre-amp is used? So when your receiver is connected it's shut off.
You could try something connected to it's own pre-amp (if it has one) and see if it goes off when there's no signal from that.
Jan 30, 2015 | Audio Players & Recorders
Does it matter at what time I take a pre-workout supplement?
Yes, Time matters a lot.
As your body needs some time to absorb all the nutrients and direct them to your bloodstream.
The best time to take pre workout supplements is 15-30 minutes before you start your workout.
If you want to get all detailed information about pre workout supplements and the guidelines to buy them then you can refer Weighted Training clothes.
Feb 04, 2013 | Health & Beauty
Can i hook up a power amp to my denon avr-3300 with out a pre-amp
Yes. Your receiver has the required pre-out connection terminals needed to go to an external amplifier. That would make your receiver operate as the pre-amp/processor.
Feb 21, 2012 | Denon AVR-3300 Receiver
Can I connect a turntable to my Sony mhc nx3av system which I got 12/13 years ago and it is great. Will it be accessed via the MD option? And must I get a turntable with a pre-amp? Thanks in...
YES, you can not only connect a turntable but also a VCR or DVD player or other analog audio sources using either of the top two RCA INPUT jacks on your unit. Now, for a turntable, you will need to buy a pre-amp because typically a turntable provides too low a signal level for most components to handle. These pre-amps cost $35 and up. Most turntables do not provide a pre-amp. Usually an amplifier or receiver will contain the pre-amp and have PHONO inputs specifically for a turntable. So you are correct, you need a pre-amp of some kind. Be sure to select the inputs on your Sony where you connected the turntable when you want to play records. Hope this helps.
Mar 14, 2011 | Audio Players & Recorders
Looking for sequence of operation for a lennox mid efficient furnace
When there is a Call for heat, the control delays ignition until combustion air
Blower operation has been proved and pre-purge period
Has elapsed. It then opens the gas valve and generates a
Spark to ignite the burners. Trial for ignition lasts for 7 seconds.
At the same time, the control begins monitoring the
Flame sensor. If the flame current is too weak (less than 1
Micro amp) or if the burners do not ignite (within the 7 second
Ignition trial), the control will shut off spark and the combustion
Air blower and de-energize the gas valve. Flame
Current should be between 1 and 5 micro amps to keep the
Gas valve open.
The control will attempt to ignite the burners up to two more
Times. Each time the control restarts the ignition sequence,
It begins with a 45 second pre-purge. If flame is not sensed
After the third trial, the control locks out. Lockout means that
The control shuts off the gas valve, spark and combustion air
Blower for 60 minutes. At the end of 60 minutes the control
Completely resets and will attempt ignition up to three times.
The control can be manually reset before the end of 60 minutes
By momentarily turning off power to the unit.
here is a link to an operations manual
http://0190acd.netsolhost.com/manuals/80MGF_Series.pdf
Nov 25, 2010 | Heating & Cooling
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
ION turntable volume is low when plugged into a receiver.
Either the cartridge has failed, or an internal amp in the record deck has, or despite what you say the receiver has. I will clarify this for you. Magnetic cartridges need a pre-amp before it gets amplified by the pre-amp and power amp of your reciever. If that pre-amp fails you will still hear the low sound from the deck, but all others cd/tape would be normal as they don't go into the deck pre-amp.
All you need to is trace the circuit. Find the magnetic cartridge pre-amp and find where it joins with the pre-amp of the amp! If you stick a screwdriver at that point, you will get a buzz at normal volume on each channel. The cartridge pre-amp has gone if you do get a buzz!
You probably find it's a single IC that's gone, some are prone to static problems.
Jan 01, 2010 | ION Audio iTTUSB Turntable
Diagnostic Indicator
Beep codes and power LED status are pre-post errors. Usually beep codes indicate a problem with a memory module. Power LED is solid green for normal operation. Solid or blinking Amber color power LED indicates a power distribution problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Dimension 2400 PC Desktop
I am trying to hook together a computer and a turntable(Turntable has its own pre-amp) & I need a diagram on what wire gos where?
OK. Since there is a pre-amp, all you need to do is to connect pre-amp output to Line-in input on the PC. This may be a bit of challenge as the connector on the pre-amp and computer are of different types. Usually, you need a cable with RCA connectors on one end and 3.5mm stereo pin (same pin as you have for stereo headphones) on the other.
Aug 17, 2008 | Sony PS-LX250 Turntable
Myryad M Series MDP 500 7.1-Channel Amplifier Logo
171 people viewed this question
Top Myryad Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Myryad Audio Player and Recorder Expert? Answer questions, earn points and help others
