I am unable to set up my Hyundai Jumbo remote control.( HY7237)
I have an LG Plasma 42'' TV with a built in hard disc and Freeview. I have tried to obtain setting up instructions for the Jumbo control but up to now have not been unable to get ones which will give me control.
I would be obliged if you can help.
  • 4 Answers
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
Posted on Jan 06, 2008
SOURCE: dmtech remote control programming codes
I have been looking for the same codes myself and all I have found is: 0157 0159 0335 1994 2024 2031 0067 0312 0910 0208 0586
hope one of these work for you.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
  • 403 Answers
SOURCE: I need instructions and codes to program jumbo remote control
Try this, just be patient when programing it might take a couple of minutes to program.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 30, 2009
rmoseng
  • 77 Answers
SOURCE: iwave Jumbo Universal Remote hookup
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button. If your TV is not listed use the auto-setup function.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Posted on Dec 17, 2009
Does a 50pb56 lg plasma tv have freeview built in,cant seem to find using remote,have just camcelled sky
Call an LG Support Representative.
(800) 243-0000 Consumer (6am-midnight CST)
Apr 21, 2017 | LG Televison & Video
What is thecode for LG plasma TV on jumbo innovage remote?
Try these codes.
0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Apr 01, 2012 | RCA RCU600M Remote Control
Lg 42pg20 remote won't work how to program
Hello
Buy a univesal remote control, which have setup codes for LG tV. You can get this information from the catelogue accompanied with the remote control. There will be proceedings also to setup the remot to tV. Or get its orginal remote control from the authorised service center for LG at your town.
Feb 27, 2012 | LG 42PG20 42 in. Plasma HDTV
Do you have the sky remote code for my LG 50ps8000?
hi,
sky remote control doesn't have code for ur lg tv. better u purchase a univesal remote control.
ok
Dec 15, 2010 | LG 50PS8000 50" HD Ready 1080p Plasma TV...
Upgrading to freeview HD
Simple answer is no unless Panasonic decide to release an upgrade to the software to allow it
May 01, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Need codes for Innovage Jumbo remote control with a Freeview box.
hi can anyone HELP I HAVE COBOLT JUMBO REMOTE BUT NO CODE FOR ACCER LCD
Dec 25, 2008 | Universal Remote Control Remote Control
LG 42PX5D Sound issue
if you believe that you are having a problem with the sound decoder then i will advice you to have a tech repair or look at your set if you are not a qualified tech.good luck.
May 06, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42PB4D 42" Plasma TV
This worked for me too! THANKS
Dec 04, 2007 | LG 42PB4D 42 in. Plasma HDTV
Hyundai 42" Plasma TV
Try www.hyundai-world.com That is the manufacturers website. Good luck. Ask them if that set can played in the USA without a special power supply.
Nov 19, 2007 | Hyundai HPT-4250 Television
Televison & Video Logo
306 people viewed this question
Top Televison & Video Experts
