Question about Sony KV-27V22 TV
Kp-46wt510 rear projector from sept. 2003
It was working fine. Shut it off last night and in the morning it came on but it looks like you have on 3-d glasses on , a rainbow of colors about one inch apart from each other also a small gap on top and bottom with a slight arch. I open it up and cleaned it some no difference in picture
  • Anonymous Aug 21, 2008
    I have same problem. Can see lines of green and blue colors. Audio is ok.
    Novelist:
    Champion:
  • 236 Answers
You have a failure in the convergence circuit. There's a circuit board ( the convergence board) which has 3 IC'c on it that drive yokes on each of the picture tubes red-green- blue. You probably lost power to these IC's or one or more may have opened up. Sometimes poor solder joints on these IC's will develop causing loss of convergence. Hope this gives you an idea as to where you problem is. Stargazer
Posted on Jun 02, 2007
SOURCE:
The TV is working fine. HD looks amazing. The
Your optical engine has a problem and to solve the issue you brought up you would need to replace it. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the process to change the engine. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 24, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My 51" sony rear projector has blue shadow on image. pictures are fine but it has blue shadow. how can I fix that?
Clean the mirror or the blue color gun. You may have it next to a powerful magnet from a speaker system that can also distort the blue. If thats not it it may be bad convergence ICs
Mar 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a KP-46WT510 and have replaced both STK chips and 1 fuse on the power supply board. Under the heat sink there is another fuse burnt. The value of the fuse needed is 3.15 A. I put in a 3 A fuse and...
I have worked on about 5500 projectors in the past 10 years.
There is a dead short already somewhere so you cant blow anything else up if its a fast blow fuse.
Disconnect the Convergence Amp from the pwr sply then power it up for a few seconds with your 4amp fuse. Does the fuse still blow? If so, check the HOT transistor. (3 pin chip againts the largest heat sink)
Good luck
Dec 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Red red wavy lines across the TV screen
I did not fix the problem, but you have the model number wrong, it is KP-46WT510
I do need some help.
Nov 23, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-46WT510 Rear Projector TN
Try to hard reset the TV that is Unplugg the device for 30 mins or an hour and then connect it back..It will help you essentially..!..Thank you..
Please post back on how things turned or for further assistance..!..
Regards!!..
Jul 23, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 Rear Video Projector Convergence Problem
Subject
Video bowed in, convergence out, PS5001
Symptoms / Customer Description
Video bowed in and convergence is out.
[Primary Symptom Code: 1436 ]
Solution
Found PS5001 on G board was open.
HQ Comments: Could be cold solder joint on one of the STK IC's on the D Board. They run hot and the solder connection might have broken down causing intermittent condition which could have opened the fuse on the
-22v line.
You can find the full repair manual Here!
Nov 18, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence
You need to go to http://www.partstore.com, enter your model number,look up under that model number STK #(@-560. Order Two of the part number 874901908. These also need heat sink grease in the back of these ICs when they are replaced. If you know how to solder, then good luck, and please be carefull!.. Please do not forget to rate this thread.
Nov 26, 2006 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
