Question about Polaroid FLM-2625 26 in. HD-Ready LCD Television
VGA Input Hi, Just unpacked ,u 26" Polaroid LCD HDTV and it looks great, first thing I tried was to plug my PC in but the TV displays a message in the top right corner that says 'Not Support'. CHecked the manual, no specific problems but one thing I did notice was that the screen thay display in Menu Setup is different to the screen I actually get. Please can you help me with how I can get my PC to run through my new TV. Martin
    Top Expert:
  • Polaroid Master
  • 83,843 Answers
If it says no support then it can't read the computer. There is no way around this unless you have a RGB (this is a computer input port) input port on the TV
Posted on Jul 10, 2017
3 Suggested Answers
  • 44 Answers
SOURCE: When we turned on the tv it says no signal vga
This might sound like a silly question but is the VGA input the one you wish to use?
If you are trying to use the VGA input what do you have it connected too?
A) Laptop 2nd VGA output.
B) Desktop VGA output.
NOTE: If you trying to connect it to a laptop you may have to engage your 2nd VGA output by depressing the 'Function Key' and either F4 or Some times it's the F8 key at the same time.
Blessings,
A/V Media Tech Guy
Posted on Nov 24, 2009
SOURCE: Polaroid LCD-2000 no VGA input option
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Posted on Feb 28, 2010
How do i use as a pc monitor?
Well if you have an HDMI output on your pc you can use that or if the TV has a VGA input you can use a VGA cord and select your TV input to PC
Apr 06, 2015 | Polaroid TLAC-02255 22AA€A LCD TV...
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
Sep 07, 2012 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
I am trying to hook up a 26 inch viZio to my hip desktop utilizing the VGA cord. It won't come up? I am on the comp screen on the tv also.
Once you plug the VGA cable from the computer to the VGA port on the tv, get the remote for the TV and go to the Select Input function so that you can select PC or Computer as the input source. Then Reboot the Computer.
Once the computer reboots it will probably display on the tv. If not, Press and Hold the FN function key on the computer then hit the correct key (F1 thru F12) that toggles the display. The correct key (F1 thru F12) will have LCD/CRT on it or it might have the icon of a display.
Once it is pressed the video should toggle each time you hit it from showing on the Computer only, TV only, both the TV and Computer.
Apr 14, 2012 | HP Computers & Internet
How to PC Monitor Input
use a vga to vga cable and a 3.5mm jack to 3.5mm jack lead like these
you will then need to to switch to pc input and your computer should display on the tv, if your using the tv as a secondary display from your computer. I.E. you already have a monitor connected or its a laptop you will need to go into display properties in your control panel and click on settings and then enable the second display.
Apr 22, 2011 | Memorex MLTD2622 26 in. LCD TV
How do i connect my pc to my tv
Used the VGA cable came with ur computer monitor,used that VGA cable plug in VGA input it the tv and plug it other end to the computer video card.Used ur tv remote look for a input button pushes look for the mode computer signal in the tv like input 1,2,3..so on.
Feb 12, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
I want to use the 23" Polaroid LCD as a monitor.
use your VGA or a DVI input and set your tv to pc mode thru the tvs menu. you should not have to instal any drivers at all. your tv as a monitor will display all text and images as a monitor the same as it does as a tv
Jan 04, 2011 | Polaroid TLX-02311B 23 in. LCD TV
Macbook - Lg TV
Take a look at these discussions:
http://macosx.com/forums/hardware-peripherals/304718-connecting-macbook-lg-hdtv-rz-32lz55.html
http://discussions.apple.com/thread.jspa?threadID=1398546
Maybe a solution.
Good luck.
K.
Jan 04, 2010 | Apple MacBook Mac Notebook
I have a vga cord
the VGA cord with your tv is if you want to use your Laptop/Pc with your tv, you plug it in where your monitor lead plugs in at the back. hope it helps
Apr 01, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
PC to TV Picture
try a DVI/digital cable on the HDMI inputs
Jan 11, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Polaroid FLM-2625 26 in. HD-Ready LCD Television Logo
53 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
