Question about Maytag MFC2061HES Stainless Steel French Door Refrigerator
How to Replace Water Filter Head on Maytag Refrigerator?
I own a Maytag Model MFC2061HES French Door Refrigerator. This is the Model that has the Water Filter on the upper right of the refrigerator. The Refrigerator got too cold and ice formed on the Water Filter head (the "male" part you "plug" the water filter into). It is now leaking. I ordered a new Water Filter Head, but cannot get any information or a procedure to replace it. Does anyone have any ideas? Thanks in Advance...
  • 4 Answers
SOURCE: Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Posted on Jul 06, 2007
aborcass
  • 2651 Answers
SOURCE: maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Posted on Mar 12, 2008
  • 1073 Answers
SOURCE: trouble shooting defrost system
you can not manually start a defrost cycle
go to the freezer and check the heater and bimetal they are in the evaperator coil if these parts check good then replace the adaptive defrost control
Posted on Apr 25, 2008
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
docjohn174
  • 943 Answers
SOURCE: Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
Posted on Oct 03, 2008
Freezer works, fridge warm
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Maytag MFC2061HES Stainless Steel French...
My Maytag French Door refrigerator MCFC2061HES recently started making a buzzing noise. The refrigerator is 5 years old. What is the problems. Please tell me it is not the compressor.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 16, 2010 | Maytag MFC2061HES Stainless Steel French...
Refrigerator not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hkare
May 25, 2010 | Maytag MFC2061HES Stainless Steel French...
Bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Jul 29, 2009 | Maytag MFC2061HES Stainless Steel French...
Maytag MFC2061HES Not cooling Either Fridge or Freezer
Replace the relay on the compressor and it should start working.
Jan 12, 2009 | Maytag MFC2061HES Stainless Steel French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Water dispenser
I just waited a couple of days without touching it. This afternoon, I attempted to use it with the filter cap on and it worked. I then emptied out two large glasses of water and proceeded to replace the new filter. It IS WORKING!
Jul 25, 2008 | Maytag MFC2061HES Stainless Steel French...
Maytag Refrigerator MFC2061HES - temperature control
Maybe. Is the compressor staying on? If it is...then the temp controller may need to be replaced. If it is cycling regularly, then you are iced up and the controller can't do much to help you. Fully defrost. Takes 2 days to melt it all. Then let's see where we are.
Dec 22, 2007 | Maytag MFC2061HES Stainless Steel French...
Maytag MFC2061HES Stainless Steel French Door Refrigerator Logo
867 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
