Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Lights flicker and door stops. both up and down.
This is a 1/2 hp on a 16 foot door. when opening or closing the lights on the opener will flicker and the door will stop. I have adjusted the torque setting to the max setting and have also changed the 110 volt outlet it is pluged into. The door runs freely when opening it manualy. This unit is a craftsman and is only about 1 1/2 years old. FYI I live in northern Iowa and have not had this problem until the temp went below zero.
    Champion:
  • 244 Answers
Do you have a duplex outlet that unit is plugged into? Try plugging a lamp into other outlet and see what happens to it when you run door, watch torque settings. they effect safety.
Posted on Jan 15, 2009
41a4315-7d remote opens garage door, but it won't close it; in order to close the door i have to use the wall mounted button and hold it down until the door closes all the way to the concrete. if i...
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Aug 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener from sears will not close the door from the outside. i have to go back in the house, close it with the button on the wall, then go back out. It does, however open the door when I...
If when you try to close the door with the remote it starts down and then the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Each of the sensors has a small light that should be lit and not flickering. Tweak the sensors a bit. If you cannot get both lights to come on you have bad sensors.
Sep 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
HAVE A 1/3 HP CRAFTSMEN OPENER THAT WILL OPEN WITH THE REMOTE BUT NOT CLOSE MUST HOLD THE HARD WIRE BUTTON TO CLOSE. GREEN LIGHT IS FLASHING.
If the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Make sure they are pointed at one another and the small lights on each one is lit and not flickering. Tweak them to see if you can get the lights on. If not you have a sensor that has failed.
Mar 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Problems with door
Check your door sensors. Make sure the small light on each one is lit and not flickering ever so slightly. Tweak them a bit.
Feb 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Sears Craftman garage door opener closes about 1/3,stops,and reverses.When I activate the remote again it stops rising,starts down again, comes down another foot or so,stops,reverses etc.,etc,etc It...
If the main light is flashing 10 times when the door reverses it is a door sensor problem. One may have been bumped so that they no longer point at one another. Make sure the small light on each sensor is lit and not flickering. If this isn't the case you might need to increase the down force a little. The control is on the back panel near where all those white wires go. Increase it about 1/4 turn and try.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Myt 1/2 hp craftsmand door opener clicks and light
If the main light flashes 10 times when the door reverses it is a door sensor problem. Each sensor has a small light that needs to be lit and not flickering for them to work. They must be pointed at one another for the lights to be on. Tweak them a bit and see if the lights come on. If not you likely have a bad sensor.
Oct 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close entirely
door will not close all the way. will go partway down then reverse itself.
Oct 20, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
80 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
