Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint Ultima Extra WDM73 purchased from a friend about 3yrs old worked when she had it since being plumbed into my flat Error E11 before washing all pipes checked and connected help please
  • Barry Coates
    Barry Coates May 11, 2010
    Hi.
    can you verify the error code is E11 and not F11, as these 2 codes both apply to Horpoint washer /dryers, and they mean differant things?
    Thankyou.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
F11 can be no hot fill so is your water turned on?
Posted on Jan 27, 2009
My hotpoint ultima is not heating, the drum spins. could you advise what the problem is
For most Hotpoint (and other named) models there is a common problem often indicated by 'F08' which decodes as 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause).
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
Sorry we cannot be of more help!
Good luck, John C
Mar 18, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
My Hotpoint wdm73 won't drain. how do I fix it?
  1. You will need to gain access to the drain pump through the bottom of the Washing machine. Remove the Drain hoses from the pump, clear any debris, change, etc. If it is clear, or the error continues after clearing, replace the drain pump.
  2. If you replace the drain pump and it still won't drain, you will need a new Control Board.
Feb 27, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Hi, i got a hotpoint ultima extra washer dryer, code WDM73, it does a wash but at the end of a cycle it wont drain the water, it says check the outlet pipe but theres nothing wrong with it, i dont have a...
try bottom front right hand side is a filter ,...undo ..water will come out so have some towels ready... clean and refit... bsc appliances 07779933829 spares and repairs.
Feb 27, 2011 | Hotpoint Washing Machines
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Jun 19, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Machine keeps stopping
if its right at beggining of wash could be pump blockage chack for coins or ffluff blocking filter
Nov 12, 2008 | Hotpoint Ultima WD72 Front Load...
The whole tub has to come out then split,it is worth changing bearings at same time.Parts can be supplied by us.
Oct 10, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima extra washer dryer WDM73
i found this manual,if you know what your problem is this might show how to change the faulty bit. I dont know what machine this is but they all seem pretty simular, i used this to change my door lock.
Jun 02, 2008 | Hotpoint Ultima WD72 Front Load...
Do anyone know what e11 mean on hotpoint wd71 pls
It means "No hot/cold fill" and recommends - Check the water supply, inlet valve and hot and cold hose connections.
Mar 27, 2008 | Washing Machines
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
217 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
