Today teh light on my wireless switch has not come on
Worked perfectly yesterday. Started up my machine but the wireless network indicator light does not come on. Have switched it off and on but no sign of life. Have rebooted both my machine and router etc... machine is only six months old. When I connect using ethernet I have no problem but wireless is much more convenient.... thank you!
  • hawky72 Apr 29, 2009
    Mine came off too, was working fine yesterday then today bam its gone, no light no driver. Computer is acting like it was never there.
  • Anonymous Apr 29, 2009
    Cannot get wireless light to come on. Have tried enable in network adapter propertys, also tried starting some service. Still doesn't work
  • 72 Answers
What make, what model? Varies from model to model.
Posted on Nov 27, 2009
    Scholar:
  • 143 Answers
Your wireless network adaptor is diseble go to network placess propaties then selact wireless connacter enable it's help u
Posted on Jan 06, 2009
How do I get my Slick HP 921 Wireless headphones to work
  • Goodmorning, I received Slick HP921 Wireless Headphones yesterday I have perfectly utilized them yesterday but today I have no communication between the wireless transmitter and the wireless headphones without changing anything since yesterday.
    The wireless transmitter is turned on but it's not trasmitting. The headphones work perfectly with fm mode and also when i connected the single green plug with other devices ( pc, phone ).
    The problem should be in the wireless transmitter.
    What I have to do ?
Dec 26, 2012 | Audio Players & Recorders
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
May 08, 2012 | Epic 450 Mx Treadmill
Wireless network has disappeared.
After resetting it (pressing that inset button with a paperclip or pencil), try connecting to it with a wire (cat5 network patch cable). Login with the default of no username and "admin" password. If that doesn't work, it hasn't been reset yet (unless the manual tells you otherwise). Make sure the wireless is enabled AND that the SSID is set to broadcast, not remain hidden.
Feb 24, 2010 | Linksys WRT54G2 Wireless Router
95 Surburban 6.5L diesel Overdrive "LOST"
Check your tow/haul switch and see if it is stuck. May have to use diagnostics to see it. Unfortunately this would be dealer level diagnostics...
Aug 27, 2009 | 2004 GMC Sierra
Wireless doesn't work on f700
The internal network adaptor may be fragile, and not secured properly. However, I would not suggest you try to secure it as it may break.
So, just make sure your wireless LAN device driver is properly installed. TO check, right click my computer, properties, then "hardware" tab, then device manager. There, check for your driver under "Network Adaptors" and see if it is properly installed.
If it is not, you can re-install it from the company's support& download site.
If it is installed, go to a more experienced techician to securely fasten the internal network adaptor in place.
Jun 19, 2009 | Compaq Presario 700 470024-192 Notebook
Wireless adapter not visible
Is it not physically connected or is there an on off slider switch thats turned off ?
Still does not explain why its not showing up in device manager.
Apr 15, 2009 | IBM ThinkPad T43 Notebook
Wireless not functioning
HI there,
Check the hardware. Most network problems stem from improper software and hardware settings, but occasionally hardware failures are responsible. If a shared Internet connection seems to be down, try to watch a cable television channel if you have a cable modem or use the phone if you have DSL (Digital Subscriber Line) to see if the entire service is down. If it is, contact your ISP to see if there is a problem in your area. Check all cable connections and consider replacing Ethernet cables if the problem seems to be confined to a particular computer or device.
Click on the HERE..
Thank you & post back how things get done..
May 21, 2008 | Toshiba Satellite M45-S331 Notebook
Computers & Internet Logo
361 people viewed this question
David Payne
David Payne
