Question about Sunpentown 1500W Heater Fan Humidifier Humidifier
The humidifer on the Sunpentown SH-1500 heater
Only about 2 table spoons of water are evaporated per day.
what can I do to increase the evaporation
  • 5 more comments
  • obri1029 Jan 08, 2009
    I dont' beleive that the country I am in has any thing to do with my problem and the humidity is low is why i have a humidifier heater I am in the USA
    I am sorry that you do not understand my problem as the fan mortor jhas nothing to do with the water heater and the fan works great please explain to me what you know about my heater I wander abnout your expertise
    Marvin O'Brien
    My humidifier heater does not work properly as it only wevaporates about two table spoons of water daily
    please do not respond untill you understand my problem the fan has nothing to do with it
    and please send E-Mail as you indicate
    Not good enough I can read
  • obri1029 Jan 10, 2009
    I received great explanations about humidifiers that have absolutely nothing to do with the heater in question. The Humidifer heats water with a 25 watt heater and evaporates it and has nothing to do with a fan or pump type humidifier please answer my question about the Model SH1500 sunpentown heaters water evaporization system
    Please ask some one with knowlege of the Sunpentown heater to respond.
    thank you
    Genius:
  • 1,239 Answers
Hi i think the thermostat is the only problem
Posted on Jan 10, 2009
    Sergeant:
    Novelist:
  • 326 Answers
The evaporator is located near the back of the dehumidifier, right above the water-collection container. It also resembles a radiator or a coiled-up set of tubes. When the dehumidifier's humidistat senses increased humidity, it cycles on, which starts the compressor and circulating fan.
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
  • Sunpentown Master
  • 19,396 Answers
    Sergeant:
  • 378 Answers
he most common humidifier, an "evaporative" or "wick humidifier", consists of just a few basic parts: areservoir, wick and fan.
Wick The wick is a filter that absorbs water from the reservoir. Evaporation of water from the wick is dependent on relative humidity. A room with low humidity will have a higher evaporation rate compared to a room with high humidity. Therefore, this type of humidifier is self-regulating: As the humidity of the room increases, the water vapor output naturally decreases. These wicks regularly need cleaning and replacement — if this does not happen, the humidifier stops humidifying the area it is in and the water in the tank remains at the same level.
Fan The fan is adjacent to the wick and blows air onto the wick, thus aiding in the evaporation of the water within.
Posted on Jan 08, 2009
    Sergeant:
    Scholar:
  • 199 Answers
A humidifier is an appliance designed on the principle of evaporation to increase moisture in the air. Water from a reservoir is added to an evaporation pad. A fanblows air through the pad. Fine droplets of water are placed in the air, thus increasing the humidity of the room. Both room and tabletop humidifiers work on this principle.
The two types of evaporative room humidifiers are drum and pump. A drum humidifier gathers water into an evaporation pad by immersing the pad, wrapped around a drum, into a reservoir of water. Water dripping from the rotating pad is absorbed by air current produced by a fan. A pump humidifier uses a pump to gather water from the reservoir and distribute it through the evaporation pad. Air from the fan blows through the pad and picks up the droplets to moisturize the air. Both types of humidifiers have operational controls, an evaporation pad, a fan, a water reservoir, and a humidistat. Some Forced-Air Distribution systems include an evaporative humidifier that works in the same way.
An ultrasonic humidifier works on completely different principles from standard room humidifiers. It's electronic . Beyond normal cleaning and testing of the electrical cordor switch, service of an ultrasonic humidifier should be left to a service technician.
What Can Go Wrong?
As you see, evaporative humidifiers are relatively simple appliances. Many humidifier problems result from dirty or damaged evaporative foam or filters. The electrical cord may malfunction. The humidistat, float control, and fan can be faulty.
The humidistat is sensitive to the level of moisture in the air. If humidity is lower than the control point set, the humidistat turns on the fan and pump (or pad rotator). See below for service instructions.
Many humidifiers have a hollow float inside that helps control water level, or tells the operator (that's you) when to refill the reservoir. In some cases, you'll need to adjust or replace the float
  • for more help click the link
http://www.fixitclub.com/Small_Appliances/Humidifier.shtml click the link
  • 89 Answers
I would check the fan and the heating element
  • dragon_rag27
    dragon_rag27 Jan 08, 2009
    do you have hard or soft water? it could be clogged
  • dragon_rag27
    dragon_rag27 Jan 10, 2009
    do you have hard or soft water as it could be coating the parts with a mineral build up which can greatly reduce the amount evaporated
    President:
  • 846 Answers
Some humidifiers just don't get high enough humidity to reach such a high percentage. If there is a way to "increase it, the instructions would be in the manual.
  • Quickfx PC Repair Jan 10, 2009
    You have to understand that ppl are trying to give you suggestions, truth is some things just can't be done so "increasing the evaporation" may not be possible. If there was some simple way to do so it would be in the manual and I don't see it being that complicated if there was a way. Sometimes you purchase an item and it just doesn't preform how you expected it to try returning it and getting a different one then. I looked up the manual on your model it says nothing about it, no one has ever commented about it other than you.
    President:
  • 2,110 Answers
Try To replace a bad fan motor, unplug the machine and disconnect the fan wires from the switch panel. You may have to pry apart a plug, use needle-nose pliers to pull the connectors off the switch, or unscrew the connectors.
1. Remove the old motor from its housing, using a Phillips screwdriver or a nut driver and socket.
2. Remove the fan blade from the motor. Use adjustable pliers to open the spring clamp at the center of the fan blade, and then slip the clamp off. Use a flathead screwdriver to gently pry off the blade, then set it aside.
3. Take the motor to an appliance store to buy a replacement.
4. Install the fan blade on the new motor, then install the motor and reattach the wires.
  • Sibananda Jena
    Sibananda Jena Jan 08, 2009
    the connectors.
    2.
    it aside.
    Sergeant:
  • 431 Answers
Check the motor and the fan blades of the humidifier properly and if needed replace it
  • 153 Answers
The fan motor has to be replaced .
Posted on Jan 06, 2009
    Brigadier General:
  • 5,158 Answers
What country are you in... winter time is low humidity to begin with.
Robert
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
Why does my machine keeps turning off
This question needs to supply more information than it currently does. Who manufactured your humidifier? Model of your humidifier? Details about when it 'shuts off', such as water level, temperature, etc.
Most humidifiers are designed to shut off when conditions reach an unsafe condition, such as water level too low. Generally this is sensed by some sort of float telling the device to shut off. Another method used is by monitoring the temperature in the device, after all 'humidification' is done by evaporating water into the surrounding air. If the temperature rises above 212 deg f (boiling point of water) it thinks there isn't any water left to add to the air so it shuts off for safety reasons.
The best course of action is to contact the manufacturer directly for details.
Apr 02, 2015 | Humidifiers
I am not getting any moisture. The fan just runs but no water is being evaporated?
How old is it? it may be time for a descale. Do you have any CLR or a janitorial or restaurant or dairy quality delimer/descaler?
Nov 28, 2013 | Hunter CareFree Plus 33222 Humidifier
I hooked up my humidifier, and everything seems to be working fine, but I was surprised to see how much water accumulates from the drain...what is a normal amount of drainage over ther first 24 hour...
There is no "standard" amount of water that will be used.
This is a flow-thru type humidifier, which means water runs through an evaporative pad and air blows over it to evaporate the water and humidify the house.
The amount of water the unit uses will depend on the house water pressure, humidistat setting, outdoor conditions, the condition of the humidifier pad, the temperature of the air flowing over the pad, the size of the house, the number of people in the house, the amount of of moisture-absorbing material in the home like textiles, carpeting, drapes, furniture etc., and temperature in the house. There are other factors as well.
The humidistat should be set to the lowest point possible and still provide some humidification (so you don't get zapped by touching metal objects or light switches). Some stats are calibrated in percent, while others simply have numbers on the dial. If you have the stat set too high, you may see frost forming on windows or around doors, in which case the setting should be lowered.
Feb 17, 2010 | Honeywell HE220A1019 Whole House...
My forced air central humidification system does not work
you need tocheck for power at solinoid valve or continuity of valve where water enters the unit. THe furnace must be on and humidistat calling...
Mar 12, 2009 | Humidifiers
The humidifier has stopped producing mist
boogiecheck is right, the one pictured uses natural evaporation( no white dust) I just ordered one from abdistrsupport@gmail.com and mine works great. I own 3 total.
Dec 07, 2008 | Venta - Airwasher LW44 Humidifier
Humidifier not collecting water
To both, these sound like de-humidifiers. Is your goal to reduce humidity and dry your room?
If so, if the humidity is low, then the de-humidifier has no work to do. A cheap battery or dial humidistat will help.
If not, check for a clogged filter. No air moving spells no de-humidification.
Also check for a frozen evaporator coil. Same as above but this requires repairs.
Electric dehumidifiers are similar to refrigerators and window AC's. With the fan running, adjust the setting to a lower humidity setting until you hear the compressor kick in. If it does not even at the lowest setting, check the space relative humidity to make sure it has work to do. If it does, repairs may be as simple as cleaning electric contacts in controls or as bad as a refrigerant leak or compressor failure. If its bad, better to replace.
A humidifier adds moisture. If you have a humidifier and want to keep the static off your clothes and keep your nose from drying out, fill the tanks with water and add biocide.
Please do not view my comments as patronizing. Even seasoned engineers have difficulty grasping humidification.
Sep 03, 2008 | Humidifiers
Aprilaire 600 bypass water flow rate
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Mar 04, 2008 | Aprilaire 600 Humidifier
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Humidifier
I have the evenflo cool mist humidifier, model # 758100. There should be a model number on the unit. As far as replacement filters, you can buy the Holmes humidifier filter, model # HWF62. It's compatible with Evenflo. I bought a 2-pk at Target for $15.99. Hope this helps.
Jan 09, 2008 | Evenflo Evaporative Cool Mist Humidifier
Sunpentown 1500W Heater Fan Humidifier Humidifier Logo
301 people viewed this question
Top Sunpentown Humidifiers Experts
Paul Carew
Dennis
Are you a Sunpentown Humidifier Expert? Answer questions, earn points and help others
