Question about Microsoft Xbox 360 Console
4 FLASHING RED LIGHTS
Last night, my xbox 360 froze with a new game in the disc tray. I then swapped games to see if the problem was with the game. That's when i got 4 flashing red lights and now I can't fix it. I have tried to wipe off evrything and I even tried a new AV cable, but nothing works. PLEASE SOMEBODY HELP ME!!!!!!
  • 9 more comments
  • Anonymous May 06, 2008
    4 Flashing red lights.
  • shodan60 May 06, 2008
    XBox 360 console problem.Game in and it freezes.Have had the 4 red lights flashing and an error message E79.Reconnected all cables and red lights are gone but the game freezes at resume game.
    Shodan60
  • townberry Jun 30, 2008
    Was playing a game halfway when the screen froze and some sharp sound was emitted from the television speakers. I turn it off thinking it was the disc problem. So I restarted the console and reinsert the disc. Played for less than 2 minutes then the whole screen froze again. This time the 4 red lights started flashing. I turned the console off and the next time I tried to on it back, the 4 red lights started flashing non stop.
  • Anonymous Jul 17, 2008
    the solution is here
  • emfc Nov 06, 2008
    help.. 4 red lights flashing.. nothing wrong with the cable!! help
  • Anonymous Nov 07, 2008
    tree flashing lights
  • Anonymous Feb 08, 2009
    i have the same problem
  • imissjoe2008 Feb 15, 2009
    i played alot one night and the next morning i had 4 red flashing lights
  • wow cd key May 11, 2010
    Check this link out to solve this problem:http://xboxinstructions.blogspot.com/
  • wowgold May 11, 2010
    Here is the best solution of this problem: http://solvexbox360.blogspot.com/
  • ilahaa May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com.
  • 3 Answers
4 red lights is not necessarily a hardware failure or ring of death. The cause is usually from AV cable not being detected or not connected correctly. The Eraser trick is good for Error 0102 make sure which error number you have! Suggested Solutions: 1. Try to connect and disconnect the cable and see if it makes any changes on the red lights status. Note that not inserting the AV fully will cause the 4 lights error to appear. 2. Make sure the AV Cable and the connector in the Xbox console are proper and there is nothing banded or twisted. 3. Try to connect it to a different monitor maybe this is where the problem is. 4. Find the metal area where it plugs into the console this is called the AV Pack metal area. Use a dry, lint-free cloth and wipe it. Then try to plug the AV again. * If you still can't make it to work and you have your warranty just send it in. If you don't have warranty I suggest trying the live chat support on Fixya!
Posted on May 28, 2007
I had the same problem. 4 lights not long after my warranty had ran out! Microsoft wanted £60 to fix it but after alot of complianing they offerred to fix it for £30 slighty better still frustrating!
Posted on Dec 04, 2008
  • danaforsythe Dec 17, 2010
    Many thanks you for this blog which you have made by your patient and thinking power. You really know so much about this matter. You’ve covered so many bases. Great substance from this part of the internet. Thanks again for your creation.http://www.360xboxrepairguide.com/fix-xb... 3 red lights xbox 360 fix
    Problem Solver:
  • 13 Answers
FOUR RED LIGHTS is the video cables are bad. Most people are posting about the ring of dealth witch is 3 lights and means general hardware failure. Heat gun fixed my 3 lights. Been beating hours on the box for months since repair.....knock on wood!!!! Good luck . If a freind has a box try his cables to be for sure!!!
Posted on Oct 03, 2007
  • 3 Answers
Turn off your xbox wait 5 mins take all the cords out (plug them out of tv and outlet) wait another 10-20 mins then plug everything back in and restart the box if not fixed go to the sites indicated in the above comment(s)
Posted on Jan 24, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 42 Answers
If you have tried replacing the AV cable then this could be indicative of a problem with the video scaler chip (closer to the common e74 error)
Unfortunately if this is the case there is no easy way to do this apart from opening up your console and fixing the solder connection problems on the video scaler chip that are causing the problem. Basically you will have to go about the process you would use when fixing the red light of death GPU error.
Because this is quite an in-depth problem to solve you will want to use video instructions etc; at my Microsoft Xbox 360 Repair Guide blog you can get step-by-step instructions on how to fix the 4 red lights error on your console - just read the section about fixing the red ring of death.
Posted on Mar 10, 2011
I had the same problem (4 red rings) with my xbox360. I sent it to my local repair shop. Turns out that even though it flashes 4 red rings, it doesn't necessarily means that it's the AV cable problem. Sometimes, it's actually an indication of the same problem as the 3 red rings of death. The graphics card heated up too much and melted. I had my xbox360 graphics card changed and now it's back up and running fine. To avoid the same problem, try changing a bigger fan for your xbox360. You can also maintain it by putting your xbox360 on the vertical position. It allows much more ventilation compared to when you put it horizontally. You can also do it the old way by switching on a table fan directly facing your xbox360's back (the place where you connect your power and AV switch). More importantly try not to play over 3 hours every time. And when you want to switch it off, DO NOT switch it off immediately. Terminate your game by going back to your xbox360 dashboard. Then, eject the game disc out. Leave your xbox360 running (without the game disc inside) for roughly 15 minutes. This actually allows the graphic cards to cool down slowly. After 15 minutes or so, you can turn off your xbox360. I have been doing this for quite sometime now and my xbox360 poses no more problems for me.
Posted on Oct 18, 2008
Throw your xbox in the bin and buy a new one! microsoft want £60 to fix my xbox with the true ring of death then theyl give a new 1yr warranty on it.
Posted on Oct 16, 2008
Good news!
FixYa expert found the solution.
Click here for the 3 flashing red lights solution
Posted on Jul 17, 2008
I started with this problem and it gradually got worse until it wouldn't even switch on, it just brought up a set of red lights on the front (360 ring of death). I had to send mine back to Microsoft and have the motherboard replaced. Google for ring of death on 360 and you'll see your machine is probably dead.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Hey Raff, Have a look at this post, it's about 3 red lights problem. See if it helps http://www.fixya.com/support/t142158-3_flashing_red_lights Good luck D.
My console cant update say's i dont have a update disc
hire a new game from shop they put update with new games or hook up to xbox live orGet Help with Flashing Red Lights for NXE Xbox 360 | Xbox Support this site has all you needs
Jun 09, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Xbox not loading games, no error message,just open tray. Worked last night.
Try blowing the Cd rom out with tray open might just have some dust on the eye if that dont work keep opening and closing the Disc tray is that doesnt work call xbox ( 1-800-4my-xbox )
Sep 20, 2009 | Microsoft Xbox 360 Console
How to fix a xbox disc tray when it doesn't play a game
try this site:
forums.modojo.com/showthread.php?t=157866
if it doesnt work, google "how to swap an xbox 360 disc tray"
Jun 11, 2009 | Microsoft Xbox 360 Console
Laser is not reading disc says "open tray" after 2 sec. xbox 360
my xbox 360 elite has 2 red lights, which im led to believe is over heating, but it had only run for 15 seconds so cant of overheated so whats the problem? regards paul.
Jan 16, 2009 | Microsoft Xbox 360 Console
The TV screen or monitor remains black when you start an Xbox 360 console.
This behavior may occur with or without a game disc in the disc tray. The console appears to be on because the green power light illuminates and the fan continues to operate. However, the screen remains black.
Click on the IMAGE i paste here below:
Thank you,
~micro
May 21, 2008 | Microsoft Xbox 360 Console
Tray won't close
hmm never heard of this before but i know a way you can find out whats wrong
call microsofts support line for xbox consoles at 1-800-4myxbox you will talk to somone and explain exactly what you just posted and they will tell you whats wrong. it might be under there warranty as well. so just call them and see what they say
Feb 02, 2008 | Microsoft Xbox 360 Console
Xbox 360 freezes
There are some recalls on this unit. Call microsoft for help.
Dec 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
6,087 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
