Question about Whirlpool LER5636P Electric Dryer
I have a whirlpool wed5200vq and i sent it to italy...i needed a diagram of the dryer so that the electrician can fix it to work there.
  • Bill Dickerson
    Bill Dickerson May 11, 2010
    Are they on 220 volts over there?
    President:
  • 1,214 Answers
I am pretty certain you can not run that dryer over there because the motor is not rated for 50 cycle operation. Even if it is, it will cost you more for the transformer that will be needed, combined with the electrician, to be worthwhile. Just buy one over there.
There is usually a wiring diagram inside the back service panel, or in the top head of the unit if you decide to have the modifications made.
Posted on Jan 19, 2009
Wont heat
The heating element is likely bad, they do commonly fail. You can ohm them out for a test. Remove all power and the element should read continuity or short. Also if it does read OK then test from the element to the ground, chassis-it should read open or maximum resistance if not than the element or wiring is touching ground somewhere.
Any farther than that is for an appliance repairman.
Sep 19, 2012 | Whirlpool WED5200VQ Electric Dryer
My maytag dryer heating element is not working anymore, so I need to know where it is located and find the part to fix it, can you help??
Hey sparky, it's Mike. I sent you a clarifcation for the model number but have not heard back from you. This link i'm posting has a great interactive diagram for maytag dryers that might help you right away. If you need further assistance, I would love to help you out. This should be an easy fix for you. Hope to hear from you. Let me know how it turns out.
Thanks,
Mike
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram Here is the link sparky
Jul 19, 2011 | Maytag Dryers
Whirlpool WED5300VW not spinning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 05, 2011 | Whirlpool WED5200VQ Electric Dryer
Spinning but not getting hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 13, 2010 | Whirlpool WED5200VQ Electric Dryer
Belt is to small for whirlpool dryer made in Italy am I doing something wrong? But the part number 8182481 they send me matches the number on my belt. But the difference in size is about 4 inches shorter...
Right now I am dealing with this same issue I even tried two different distributors Marcone and Sundberg to see if the factory line workers screwed up but I still got the same belt.. Wrong Belt in Right Package. My customer I am sure thinks I am the idiot and unfortunately owns a piece of metal right now instead of a working dryer. Please Whirlpool get this fixed.. I made supplier aware of problem but that won't get us anywhere.... TBD
Feb 26, 2010 | Whirlpool Dryers
Need to know how to wire box to plug dryer in to. Thanks
This site has an excellent description and diagram
do a copy and paste
http://images.google.com/imgres?imgurl=http://www.ask-the-electrician.com/images/RANGE%25203-WIRE_CORD_CONNECTION_250.JPG&imgrefurl=http://www.ask-the-electrician.com/wiring-a-dryer-power-cord.html&usg=__8gcUR2ilgf_-LToGKJJ7jqmzgP4=&h=323&w=250&sz=54&hl=en&start=1&tbnid=9k3FRcTpVzSh1M:&tbnh=118&tbnw=91&prev=/images%3Fq%3D220%2Belectric%2Bdryer%2Bwire%2Bdiagram%26gbv%3D2%26hl%3Den%26sa%3DG
Oct 04, 2009 | Whirlpool LER4634J Electric Dryer
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Whirlpool Dryer
NEED A NEW TIMER NOTHING YOU CAN DO ABOUT THAT
STEVE'S APPLIANCE
516-300-3249
Apr 06, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
