Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore gas range #362-75211101
Oven will not come on -can see glow on coil but no gas releasing
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. back
Posted on Dec 23, 2006
  • 2651 Answers
SOURCE: Kenmore gas (propane) range Model #119.7488810 18-20 years old
you have a bad oven/bake ignitor, althoough you see ther glow, its not "hot" enough to allow gas flow or ignition, very common issue, 2 screws and 2 wires, probably about $75, service company gets min $225..
Posted on Oct 19, 2008
SOURCE: LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
Posted on Nov 27, 2009
  • 2605 Answers
SOURCE: Kenmore gas stove, broiler works but oven won't
Hello, I'll start by saying this may sound odd considering the info you provided, "ignitor glows...". It is actually the ignitor you'll need to replace. Being that I do service for sears I've replaced numerous ignitor's, both bake & broil, but bake being most common as it is typically used more frequently. I'll try to explain... The simpliest way to put it is this, the hot surface ignitors function like a large resistor. As the ignitor glows it reaches a value to allow the gas valve to open and lite the burner. If the ignitor is even slightly worn/off it won't ignite the burner, hence it need's to be replaced. Hope that help's explain what & why. If so please take a second to rate the solution I provided here at fixya. Good luck and thanks for visiting fixya. Macmarkus :)
Posted on Dec 11, 2009
  • 43501 Answers
SOURCE: Hello. My Kenmore plus gas range oven does not
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Posted on Jun 05, 2010
Viking oven broiler will not ignite
Your gas valve would be my first guess. Is this broiler (and bake ) lit with a glow coil or spark probe that goes (goes click, click, to light)??
If spark probe, you will have to replace either gas valve or spark board.
If glow bar lights the broil but does not glow, then replace glow coil.
Oct 18, 2013 | Dynasty DGRSC 48-6G Gas Kitchen Range
Oven range will not light. glow plug seems to be working
You need a new glo-plug. They still glow when they go bad but not enough to ignite the burner. It's a fairly easy DIY project.
May 28, 2012 | Kenmore 70102 Gas Kitchen Range
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
Feb 12, 2012 | Roper FGP300 Gas Kitchen Range
Range won't heat up
it is a glow coil , thermocouples are on units with a free standing pilot that you have to light, if you have a range like this you may need a thermocouple if not a free standing pilot you have a electronic gas iginition system that uses a glow coil, you turn on over setting and oven glows orange then iginites if this is what you have you need new glow coil, easy to repalce
Feb 03, 2010 | Magic Chef 9122 Gas Single Oven
The ignition coil on my oven glows fine, seems like there is no gas. Won't light.
it may glow but it s weak the gas wont flow
seems like alot of these going bad
I had 3 last week in my rentals
Nov 21, 2009 | Frigidare FGB24S5DC Gas Single Oven
GE Gas Range/oven Model JGBS16 The glow coil in the oven works intermittently. When it doesn't come on we find that turning the control knob on and off several time will help or if we start one of the...
could be a bad thermostat but it sounds most likely like a loose wire connection somewhere. if the coil comes on and doesnt quite glow as bright as it should, the glow coil needs replacing.
Oct 10, 2009 | GE JGBS17 Gas Kitchen Range
Oven gas doesn't come ouy. Boiler works, ignitor
Ever though the ignitor glows it may still be bad. The gas valve circuit consists of the main oven control, the igniter and the valve coil. As a properly functioning ignitor heats up, it allows more current to flow through the circuit. It finally reaches the point where it opens the gas valve. A failing ignitor will not reach that point. The fact that it glows at all tells you the control contacts are closing and the gas valve coil is nt bad. ****If you try this repair, make sure to remove power from the unit. Be careful handling the ignitor as it is extremely fragile.
May 02, 2009 | Kitchen Ranges
Oven won't heat up
hi atdowhower,for your oven to heat the[ignitor]must heat up enough to open the oven safty valve.this happens by the ignitor drawing enough amprage thru the safty valve.just because it glows it may not be strong enough.or if you see no glow it may have a broke coil in that ignitor and wont glow at wll need an volt meter to check if no glow.if soft glow,replace ignitor.shoul be very brite.God bless,tom
Jan 02, 2009 | GE JGRS14 Gas Single Oven
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Tapan gas range oven doesn't ignite
should have at least 3.5 amps min to open the safety valve
Jan 20, 2008 | Tappan TGF320 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
78 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
