Question about Itochu C.itoh CI 5000 Matrix Printer
Font problem with CITOH CI 5000 Dot Matrix Printer
I accidentally hit the setup button on my printer and now the font is too big. Could you tell me what setting to put the printer on to adjust the font? I need it to fit on 8"x11" perforated paper.
  • jack-riley Feb 04, 2009
    Same problem in reverse. Font is too small!
Need the XP driver for the citoh ci-5000. Was working well on old computer... it died, I connected it to another computer and I can't find the driver... please help, I need this asap THANKS Will
copy past this downbelow in your browser pick os
http://citizeneurope.com/drivers/dotmat.htm
Oct 06, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Set font
To set and change the font on the printer do the following;
  1. Ensure the printer is powered on and the menu is Unlocked (power the printer on with SETUP helled down)
  2. Put the pritner OFFLINE
  3. Press the SETUP button
  4. Press the button under MENU on the display
  5. Press the button under NEXT repeatedly until you see FONT along the top line of the display.
  6. Press the button under FONT
  7. Usinig button 2 or 3 youy can scroll through the different fonts available. When you see the font of your choosing press the button under SET to save the setting.
The above actions will set the font on the pritner. If you are sending commands to the printer from the computer system to change the font, this will over rule the changes you make on the printers menu....you WILL NEED TO CHANGE THE FONT ON THE SYSTEM to change the font printed out on the printer.
Aug 01, 2009 | Tally T2250 Matrix Printer
How do you perform a self test printout on the Citoh 5000
Turn the printer on, press the ONLINE button to take it offline. Press and hold the RESET button and press the QUIET/SETUP button. This puts the machine in configuration mode. Now press the FWD LN FEED button once or twice, then press the ONLINE button. This will cause the printer to print the current settings
Jul 09, 2009 | Itochu C.itoh CI 5000 Matrix Printer
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
Epson LX-300+II not printing in draft 10 cpi using visual studio .net
use courier font. it works just as draft font. no problem in VB-6 i hope it will also work with .Net as well.
tell if dont work.
asad khan
justasad@hotmail.com
Oct 27, 2008 | Epson LX-300 Matrix Printer
Font
To change font in Epson lx300+ printer,
1. Switch on the Printer,
2. Hold the Pause Button for 3 Seconds (until you here a beeb sound)
3. Now you see the pause LED blinks, now you press Font button to change the font (you here beeb sound on change of each font).
4. After selecting the font press pause button once.
5. Thats it now your font has been changed.
Mar 16, 2008 | Epson LX-300 Matrix Printer
DOT MATRIX PRINTER PROBLEM
Hi, to perform a self-test on an Epson LX300 > start with the power switch off. Press LF/FF (middle switch), without releasing that button, power on the printer. If everything is ok it will print a sel-test page. To do a Hex Dump > start at power off, simultaneously press Font and the LF/FF buttons (left & middle buttons), then power on; to revert the printer to its factory default setting(s) > start in off position, press Font (left) button then power on. (Slightly different with an LX300+) Hope this works out for you. Cheers.
Apr 19, 2007 | Epson LX-300 Matrix Printer
Itochu C.itoh CI 5000 Matrix Printer Logo
89 people viewed this question
Top Itochu Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
