Question about Linksys WRT160N Wireless Router
Wireless Network Disconnecting
Wireless N Linksys
Router = WRT160Nv1 lastest driver/firmware
Adapters = 4 x WMP300N Broadcom chip with lastest drivers
Network settings : Static IP 192.168.1.101-2-3-4 router at 192.168.1.1
Distance : router is in the corner, and all 4 computers are within 30 feets, no walls, open office. DIsplays only EXCELLENT Signal in the status window of all 4 connections.
Problem : Wireless network disconnecting often ( about 10 times a day) on both nearest and farest PC, middle distance PC's disconnecting only 1-2 times a day.
Tries : Changing PCI slot (did not change anything), test Antenna places (did not change anything, still excellent signal with conenction lost), follow ups Linksys support about MTU and other router settings (did not change anything, or getting a poorest network), reinstall wireless cards without linksys sofware (only driver inf, but probleme stands still).
This equipement cost me more than 600$ (and about 20h of job since) please give me some tips to make it workable !!!
Great thx to any help !
  • david_lacroi Jan 06, 2009
    I tried Static IP to improve the connection time between router and cards, it helps a bit, but still disconnect.
    Jo_chinmay : You think about voltage trouble ? My router's adapter is the one that came with the box, supposed to be accurate ? Maybe I don't understand your post very well, sry... could you explain more please ? I think its Router troubles 'cause all my adapters disconnects, not as often but still have same problem on all my 4 PCs.
    Thankx a lot guys
    Scholar:
  • 143 Answers
If it's yr router problem u need to change power plug or connector may if possible to chek with DLC not line control, or stabilizar it's viltage problem
Posted on Jan 06, 2009
    Genius:
  • 1,913 Answers
U have to reset your wifi router.
reset switch is in back of router and configure asgain.if u not need static ip then comfigure as dhcp
I have a Broadcom 802.11g Network Adapter and a Cisco/Linksys WRT54GS Router. The signal is extremely poor even though the router is only 10 feet away. It does not appear to be an interference issue.
You can update the Linksys Firmware to a newer version if is available, please check the Linksys support site
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54GS
Another chance is to change the Wireless Channel maybe 11, to avoid any intereference with wireless phones.
Regards,
Mar 13, 2011 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
Encryptiing
Is your router from linksys also? How many wireless computers do you have? Note that if you encrypt your router, you need to make sure that each wireless computer gets the exact encryption keys you will use on the router. Usually the linksys router page can be accessed via http://192.168.1.1. Leave username blank, password is "admin". Go to Wireless >> Wireless Security. Select WEP-128 key. Enter in a passphrase and hit generate. Copy key #1 on a piece of paper (make sure it's 26 characters) and click apply. Next, go to each wireless computer and use encryption key#1 when you connect to the linksys router.
Jun 19, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
Feb 22, 2009 | Linksys WMP300N Pre-802.11n Wireless...
I installed the software for the router but i can't use my laptop wireless
your Wifi is not Enable Yet,
you have to login into your Linksys and go to Wi-fi and Enable your Mac address for your Router..
Feb 02, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
ACER 5610Z BROADCOM WIRELESS LAN DRIVERS FOR XP
I found this from Acer's website. Just click this link, And on the list you will be able to download the driver for your broadcom wireless adapter. I hope this one helps.
May 07, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
WMP300N
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1144763512962
this page above mentione resolved your problem.
Download the driver.
Thanks
Sergio
Mar 01, 2008 | Linksys WMP300N Pre-802.11n Wireless...
Linksys WRT160N Wireless Router  Logo
274 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
