Question about Royal 1280MX Shredder
Shredder not stopping
The shredder continues to run after all of the papers have passed through.
  • Anonymous May 25, 2009
    I have the same problem. It started after I shredded some CDs, now the auto-stop feature doesn't work anymore.
  • 883 Answers
...or switch merely clogged with bits of paper...dis-assmble feed unit and clear jammed switch
Posted on May 27, 2007
Defective input sensor switch
When turned on shredder runs, dose not stop when items are finished, but must be turned off manually. is there anything I can do to fix this?
stuck ,faulty reader switch or debris is blocking or covering the sensor unplug unit and carefully look and try to clean any paper or debris in shredder
Aug 11, 2016 | Shredder Office Equipment & Supplies
Unit will not stop
Dear Hal,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that "senses" if the paper has been introduced to the shredding slot. These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing. Also, note that some shredders may have an optical sensor that may be "clogged" with paper dust.
If you shredder does not stop, the sensor may be stuck in a on position, or, in case it has optical sensor may be detecting dust or a little piece of paper may be blocking the optical sensor and keeping the motor running.
I hope this gives you some light in further investigating your problem.
RC
Apr 14, 2014 | Office Equipment & Supplies
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
Fellows C-320/C-320C shredder runs continuously. It will not stop. I have cleaned the paper sensors, and nothing seemed to change. When the machine is on and running, I(Auto On), O(Off), and R(Reverse)...
sounds as if you will need to have the auto feed sensor replaced. if they fail it will just run, thinking it sees paper. your machine is under warranty for three years from the date of purchase. call fellowes and see if they have repair depot in your area. 1-800-955-0959
Mar 31, 2011 | Fellowes C-320 Shredder
I have a brand new P58Cs and it runs continuously instead of cutting off after paper has passed through - The Fellowes website says to clean the sensors (already, after just one day??) but because of the...
most of these shredders have tiny clip sensors that have little levers that are depressed when paper is fed into the teeth if the sensors get jammed closed then the shredder rollers will keep going try cleaning the rollers free of all loose bits of paper and you should be right
take care
Jul 22, 2010 | Fellowes Office Equipment & Supplies
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
Shredder keeps running when no paper is inserted and previous shredding job is complete
Some shredders have a switch to run continuous if desired. Check for that first.
Another problem is that during a jam, the paper sensing switch can get bent causing the shredder to run continuous.
Jan 09, 2010 | Royal Office Equipment & Supplies
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
Royal 1280MX Shredder Logo
143 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Ed
Ed
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
