Question about Acer Aspire 5500 5570-2609 Laptop
5580 lcd screen problem
On the power the lcd screen black color change to blue cannot see the black color and have a interference.i connecter with externel crt monitor the monitor is ok.i take out the HDD & RAM also the same.but some time i press the main board the lcd screen can back to normal. can use 1 or 2 hours sometime 2 day.now totally fail.
thanks.
    Master:
  • 568 Answers
Dont do any more rnd take ti to service center
Posted on Feb 14, 2009
Indication Light On, Black Screen, Unresponsive
I happened the same problem and the solution must change the power pack
Jan 25, 2014 | LG M2362D 23 in. LCD TV
White screen
First see if the power on self-test (Fn+ Power) or the LCD BIST (D+Power) will run. The Diags are normally on a blue screen with white test, the LCD BIST is simply 4 Solid Color Screen looking for defects in the LCD panel.
If you hear beeps/windows sounds when the system boots and the LCD BIST test does nothing then the LCD has likely failed and you will need a new one. You can try an external monitor and see if you get video on an external screen.
If you don't then try these steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jul 17, 2011 | Dell Inspiron 1545 Notebook
Screen not working lines,color change,olny on blue screen with line down the middle
Let's see if I understand the problem: when you have a blue screen, you see at least one black vertical line in the center, and when you have other material on the screen the same line(s) is yellow (or conversely, you have a blue vertical line that stays on all the time). If I have parsed your complaint correctly, then you have a bad connection in the LCD panel or a bad LCD column driver chip. It is possible that an expert technician can solve a connection problem by "massaging" the connection or taking it apart and reassembling it, but sometimes this only creates more problems.
Replacing a failed LCD panel driver chip requires specialized equipment. Search for "LCD TAB repair" to find a company with the right tools.
Oct 23, 2010 | RCA L22HD31 22 in. LCD HDTV
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Half screen , left normal but only half usable. right was black now blue and white, Dell inspirson 1501.granddaughters so would love to fix
Reseat the video cable connection under the keyboard. If no change, press the Fn Key while Pressing power button, this will start a PSA diagnostics, there will be 2 sets of color bars appear and a Yes or No at the end of 2nd color bar, press N to start the LCD diagnostic. If the LCD is still 1/2 and 1/2 in the LCD diagnostic, you need an LCD. If the issue doesn't appear in the diagnostic, then replace the motherboard.
Jun 14, 2009 | Dell Inspiron 9100 Notebook
Motorola V557 Black Screen
Hello! The blank screen issue with your V557, could be the LCD Module itself or even the connectivity of the cables inside. Usually the interference is the cables within the handset. It garbles the screen to either a black or white color and can sometimes distort the entire display. This can be a definite sign of hardware problems.
Now without a screen to see, how would you able to even use the handset? Your device is indeed an older model and the features that it offers are not vast. It has no expandable memory to store any pics or movies or music and it barely supports blue-tooth.
In my opinion, with the hardware issues u are facing are great enough to prohibit you from using blue-tooth to transfer your media.
Thanks.
Apr 20, 2009 | Motorola Mobility V557 Cellular Phone
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Acer Aspire 5500 5570-2609 Laptop Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
