Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Lamp(lite bulb) is dead - need to buy replacement and install it
My tv (Sony WEGA KDF-60WF655) has stopped working because the bulb is dead. Do you know what kind of bulb I need from Sony, where to get it (Chicagoland or online) and what it might cost? Is it hard to install? Is the bulb located in the bottom part of the back of the TV or on the top half? We took the bottom part off of the TV but really don't know what to look for? Can a novice do this? Please advise. THanks.
Bill Fleener
  • 2,326 Answers
Click here to find the lamp for your TV. You will still need to use the existing cage assembly, once you remove the old lamp you will be able to see how it's assemble.
For the lamp replacement instructions, you will need to download the owner's manual and go to page 16 to 22 to know how is done.
Good Luck.
Posted on Jan 06, 2009
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have 60" wega tv
This is indication of lamp is reaching to end of its working life and need to be replaced to solve this issue in tv.
Lamp replacement procedure would be written in user manual of tv and it is very easy, well explained.
Please buy Sony original lamp from nearest Sony store for good picture in tv.
Thanks.
Dec 21, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I replaced my bulb on my kdf-60wf655 sony dlp and now when t.v. is powered on the green "on" indicator flashes 3 times then turns itself off. Any suggestions?
hello, make sure you've fitted the lamp in securely and the lamp cover as there are safety switches
hope it works
regards
shaun
Dec 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Replacing lamp
Lamp replacement procedure is written in user manual,check page-17
Click Sony Support to download free copy of user manual of KDF-60WF655 if required.
There are two thumb screws at lower corners if you see tv from rear, remove these screws and take out lower front panel, in center of that space, you will see lamp cover, remove it and unscrew old lamp, pull it out and put new lamp then put things back in reveres order.
Required lamp of KDF-60WF655 is available in Sony Accessories Store for $200 under part number XL-2200
Hope these info will help you.
Thanks.
May 13, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
What can make the TV to stay on for less than a minute and then turn off to do the same over and over?
Weak lamp can cause that symptoms, replace lamp in TV to fix this problem.
Lamp replacement in Sony KDF-60WF655 is easy and procedure is mentioned in user manual.
Thanks.
Oct 12, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a KDF-60WF655 and the lamp light turns on
Joann,
If you buy an original Sony lamp (and I would recommend you do) you will get the lamp with the housing and the allen wrench you need to change the bulb. You shouldn't need a ballast.The reasons to stick with an orginal Sony lamp:
1)You get the lamp with the housing. Some of the aftermarkets just send the lamp and reflector
2) the originals have far less problems than the aftermarkets. I have seen replacements fail early and not be bright enough.
If you have any further questions, feel free to ask. If you are happy with this solution, please rate it. Thanks!
Nov 18, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a Sony kdf-60wf655 60 in.rear with dark images and por colors
Lamp is cause of dark image in your tv. Lamp indicator will flash when lamp will be dead.
Nov 07, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
