Question about Roper REX4634KQ Electric Dryer
Roper REX5634KQ0 runs for two minutes in any cycle and then stops
I have had my dryer now for about 5 years and had to replace the heating element before and over this past week end the dryer would not dry the cloths. After thinking it was the heating element again I purchased a new element and thermal senser kit. Well after doing that I thought everything was ok but no luck. I got to looking closer and noticed that the dryer was not running more than two minutes in any cycle, not even (No Heat / Fluff). Also there is a increasing squealing sound that is made when I first press the start button. Also I noticed that the dryer will not restart for over two minutes. Please help, I have to get this thing going soon cloths are starting to back up.
  • boobe96 Jan 19, 2009
    Thanks Tridewebsr I believe you were correct so I bit the bullet and purchased another dryer. But I hope the solution helps someone else.
  • dacook_jimd Mar 01, 2009
    my Kenmore dryer, shuts off after a couple minutes, smells like it is burning, any ideas?
  • 198 Answers
This problem sounds like a bad motor bearing causing the motor to overheat, when the motor overheats there is a thermal protector that opens and the motor will not run until it cools down.
Posted on Jan 18, 2009
  • tom weber Jan 19, 2009
    Your welcome, good luck with your new dryer.
    tridewebsr
My Kenmore HE4 electric dryer runs for 2 minutes and stops
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replac it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Having heating problem with Roper REX4634JQ0 dryer?
probably have a weak hi-limit thermostat on the element housing or cycling thermostat on the blower housing
Apr 26, 2012 | Roper Dryers
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
301 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
