Question about Zanussi ZBF360 Electric Single Oven
Oven keeps tripping the electrics
We have a built in Zanussi oven, when you witch the oven it seems fine but once it has warmed up a little it trips the electrics.
Any ideas what could be causing this, is it fixable or do we need a new cooker?
Thank you for any help you can give.
  • amyeveritt Feb 21, 2009
    I turned my zanussi built in oven on earlier and it was on for about ten minutes before the electricity tripped. I turned the trip switch back on, and then turned my oven back on, it stayed working for a little while and now it's just totally given up, without tripping the electric a second time!!! Does anyone have a clue what's wrong? Thanks!
  • Zanussi Master
  • 3,463 Answers
I would suspect that the fan oven element is faulty. what I think is happening , is as the element gets hotter, the insulation is breaking down and causing the trip to operate, it is quite a common problem
You will need to fit a new element.
If it is a fan assisisted oven you will find the element behind a removable cover at the rear of the oven compartment..
Plz rate my solution.
Thankyou.
Posted on Jan 06, 2009
Gihighoigiugb jlkh;kj
Posted on Dec 06, 2009
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
Oven tripping
Was the oven tripping the the fuse before the element was replaced,also did you take the oven out to do element because the element can be done with cooker in place it may be that you pulled out the connections block at rear of unit and it is touching body.If tripping before replacement the fault could be any where on the oven.You will have to check it through.
May 07, 2010 | Zanussi ZBF360 Electric Single Oven
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
Intermittent tripping of circuit as oven just reaches temp
Sounds like the oven element is cracked and absorbing moisture when the oven cools down thus causing it to trip. Should buy a new element. there are hundreds of suppliers on the internet.
Jun 09, 2009 | Neff B1691 Single circotherm super...
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZBF360 Electric Single Oven Logo
1,464 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
