Question about General Electric A835 Digital Camera
Lens Error When I turn on the camera in any mode except play back, the lens will come out as if it's coming on but then the lens' go back in and the camera shuts down. The batteries are fully charged and the camera has not been damaged in any way.
  • karenorsam May 24, 2009
    when you turn on the camera the lense comes out but then the power turns off with lens still evposed. It it fully charged. And there has been no damage to the camera that I know of
    Sergeant:
  • 367 Answers
I am sorry to say but you have a physical issue with the camera. Your either going to have to take the camera apart yourself or bring it in for service.
Try working with their support
GE Consumer Electronics
1-800-447-1700
Automated response 24 hours/day, Live agent 8 a.m. - 8 p.m. ET
Posted on Jan 06, 2009
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
Nikon coolpix S3000 - lens error! - appears after turning on camera, lens goes out then in, message on screen will not go away, camera will not do anything at all except turn off. Does this mean the...
I got a same problem with different mode.
I planed to send it back to manufacturer, before packing it, I just knocked the back of camera with my palm in switch ON mode... the lens just retracted into normal position...
It can work for you to......
I am not an expert, it is just my experience I am sharing here.
If Lens struck with Lens Error!! on the screen, charge the batteries, switch on the camera, when the lens tries to move, feel free to knock a bit hard at the back of the camera with ur palm...... you cant hurt it any more than it already is., it might help the misplaced gears to aline back in if it is a minor problem.
Sorry about this un expert advice but it worked for me...
Just try it before sending in...
Feb 26, 2011 | Nikon Coolpix S3000 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
Lense problem
Dear jmgrev,
Whenever you turn your camera on and your lens doesn't go in and out properly you are likely experiencing a lens error of some sort. Look for an error 18 or a "lens error restart camera" message. If either of these appears you definitely have a lens motor mechanism problem and will need to send the unit in for service.
If the lens still functions, but only intermittently - or if there seems to be a functional problem in focusing correctly or in taking an excessive time to focus, then you are in the early stages of what will soon become a fullblown lens issue.
These problems can be caused by a variety of things such as having obstructed the lens when turning the camera at one point, or getting grit in the lens mechanism or during/after a fall or some sort of impact. It can even happen spontaneously due to the tracking mechanism coming out of gear. Hopes this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera lense/power
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2008 | Canon PowerShot A510 Digital Camera
Bonnie
I was getting the Lens Error message on my A730, even though my lens seemed to be working fine. I'd had the camera in my pocket, and apparently it tried to open but jammed. But it seemed to be OK except for the cursed Lens Error message when I'd power it on. The way I found to fix it is press and hold the "func/OK" button on the back, then turn the camera on. Now it's working again. Note that this may not work for you if your lens is actually screwed up. Mine wasn't.
Dec 12, 2007 | Cameras
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
General Electric A835 Digital Camera Logo
153 people viewed this question
Top General Cameras Experts
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
