No sound my new speakers does not give out any sound help
    Genius:
  • 1,913 Answers
Check all jack connection also check there is not mute in sound or player.
Posted on Jan 06, 2009
No sound coming out of speaker
If there is no sound coming out of the speakers, first you check if the jack is properly hooked up, and try to adjust it in the device it is connected to. If it seems not to give any sound, then it means the speakers of the headset is bad, most likely the wires in it is disconnected or cut and mostly the best solution is for you to replace it with a new one.
If you do not want to replace it with a new one, i will advice you try to take it apart and solder the wires at the back of the speakers to make it work once again.
Hope this was helpful to you. Thanks for using Fixya.
Jan 26, 2011 | Radio Communications
My blaupunkt rear right speaker just stopped giving out any sound ..it started with a tearing sound at high volumes with bass intensive songs. then next day no sound at all. left speaker works fine. Help...
As shown in the picture double check the vibration flexible wire connecting to the center, you cannot see it on your naked eyes, use tester to prove the connection, use soldering iron to reattached the broken circuit, be responsible for the connection, put in mind that it is vibrating too heavy...
Oct 21, 2009 | Blaupunkt GTx 693 Coaxial Car Speaker
New car head unit, same old problem: Garbled sound
Hello susanmillan,
If it's not the head unit, and it's not the speaker, then it must be a problem with the wire going to the speaker. When you hit a bump, the wire shorts or opens intermittently causing the faulty sound. Some insulation could have rubbed off. There could be a bad pin in a connector. The wire could have some broken strands. It could have become pinched against something sharp.
The good news is, it's really an easy fix. Just have your installer make sure that the sound is OK at the wiring harness itself, and run a new wire from there to the speaker.
Hope this helps.
Jun 21, 2009 | Sony CDX-M630 CD Player
Left speaker gives no sound
There could already be a problem with the speaker jack, if only one channel is consistently giving no sound on your system.
Try turning the male (connected to speaker wire) jack and you might hear a static crackle while doing this. If you get both channels to produce sound this way, you already have a failing audio jack, and may need replacement later on.
Hope this helps.
Jun 07, 2009 | MSI PM8M2-V Motherboard
I need a sound card installed for free
hi
giving you this link,plz click and visit the following site to get your soundcard downloaded for your speaker.
http://en.kioskea.net/s/need-to-install-sound-card-on-speaker?section=download
hope u will b helpfull
thankyou.
May 07, 2009 | Computers & Internet
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Mar 29, 2009 | Creative Labs Inspire T6100 Computer...
My desktop pc wont recognise my speakers
Go to the control panel, open device manager, check the sound system. If you have installed a new O.S., then you will need to also install a new sound system. Perhaps it ac audio 97 or some other. Look for yellow exclamation mark or yellow question mark and right click on that and update drivers.
Hope that helps.
Jan 12, 2009 | Logitech Spin 75 Computer Speakers
Poor Surround Sound
There is a setting in the dvd player to up the rear speakers to a + setting you have to dig deeep somewhere in the speaker settings. mine did the same thing till I found it.
Jan 08, 2007 | Panasonic SC-HT940 System
Computers & Internet Logo
David Payne
David Payne
