Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
We have a KitchenAid [KSRG25FKSS03]. We turned the ice maker off for a period of time and recently turned the switch back to the on position, but now no water is flowing from the black rubber outlet into the ice machine. Thus - no water inflow into ice machine, no ice being made. Any advice? THx.
  • fwy3 Jan 08, 2009
    I turned off the ice maker when the basket became full.  Now it won't work at all.  No water into the ice making unit, but water does flow through the on door water dispenser.
    The people at Kitchen Aid were not helpful at all - it will cost $81 for the service call plus $19 for each fifteen minutes that the repair man is here.
    I don't feel like spending a couple of hundred bucks to have them try to sell me a new door.
    help.
    Scholar:
  • 102 Answers
Sounds to me that the water inlet line is frozen. If you feel of the black rubber outlet, it will probably have ice in it causing it not to pour water in thus no ice production, Remove your door that is in front of the ice maker and use a blow dryer and thaw the line. Hot water can be squirted up in the line to thaw it quicker and do a more efficient job. Once you clear the line then your no ice days should be over. It may do it again and if it does then you will need to do the same thing again adding replacement of the water inlet valve.
Posted on Apr 11, 2009
Why do we hear a water draining noise on kitchenaid superba?
Hello Mari;
My name is Peter. I am a retired field service refrigeration technician.
You have a condensate drain in the back bottom of your freezer for when you go through a self defrost mode. The defrost mode is so gradual there is not enough water flow to make a noise.
What you are hearing is your ice maker filling with water. Your ice maker will fill 8-10 times within a 24 hour period.
Dec 23, 2014 | KitchenAid Refrigerators
No water to icemaker Kitchenaid french door KFIS25XVMS9
There is several reasons that could cause this. First if your ice maker has a switch turn it off for about 15 seconds then turn it back on then the push the ice control paddle in 3 times. This should start the "harvest", reach up under the ice maker it should start to fell warm to hot which is good. Soon the kick out fingers will start to rotate. If it all is working well it will kick out the ice, then fill with water. If this all works but no water, then it could be a bad water fill solenoid valve, kink in the water line, water filter, frozen supply line. Let me tell you this is at times will have you scratching your head, so have fun.
Jul 23, 2014 | KitchenAid Refrigerators
KitchenAid KSCS23FTSS01 Ice Maker Not Working
Is it getting water? The inlet valve on the back of the fridge where the water line connects is a frequent source of ice maker problems. If the It sounds like you've covered the other major issues.
Nov 28, 2013 | KitchenAid Refrigerators
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Kitchenaid Superba freezer side cuts out sometimes
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
FRS26ZNH - Ice maker arm is stopped half way through process. Arm will move to lock position, and back down half way. No ice is impeding harvest finger movement. Water was shutoff for a period of time, and...
I believe you will need to unplug, remove and dry out your ice maker and carefully disassemble and try to get everything back to the home position without losing parts. It sounds like your ice maker stopped mid cycle when power failed.Then froze in place at present location. Ice makers have a series of about six stages once they begin cycling. A cam and relay switches guide it to the next step. Yes, you can fix it yourself and you will need to guide and get all parts to align to where you see it setting most times when you open freezer door. I call that home position and if empty in that position it calls for water for about 7.5 seconds. Tedious but I will try to assist you. Sea Breeze
Mar 23, 2010 | Refrigerators
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid door ice and water dispensers don't work
Hi
If  the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | KitchenAid KSRG22FK Side by Side...
No water inflow into ice machine after turning off ice maker -
Hi, sounds sticky to me, or it wants the kids back home. But anyway try finding the travel of the tube, could have fallen off on other side, or has blockage since we have so much junk in our water today. Also although your filter is green if its good, I would take it out and clean it, not replace just clean it, and a must fine hose must be a problem, wish I was there ! Frankie!
May 07, 2017 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
280 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
