Question about Broksonic CCVG297 9 in. TV/DVD Combo
Tv on/off and volumn don't work on my dish remote
I worked with dish and the tech. support was not able to solve the problem. I can change channels and get info but can't turn it off or on
and can't control volumn with remote.
    Novelist:
    Scholar:
  • 67 Answers
If you are trying to use a Dish Network remote control, then you are probably out of luck. Most Dish remotes do not have remote codes for TV/DVD or TV/VCR combos. There are just too many codes out there to put into one remote control. I'm sure they tried to walk you through a code search (hold the TV button down, etc.), so if it didn't show up then, then you are probably stuck with using two remotes or adjusting manually.
If they didn't try a code search, then try this:
Turn the TV on manually. Then, press and hold the clear TV button at the top until all the buttons at the top turn red, then release. Press and release the TV power button (the smaller red power button), and press the channel up button. Repeatedly press and release the channel up button about once a second until the TV turns off by itself, then press and release the # button at the bottom right hand corner of the remote, and the TV button will flash 3 times, confirming that it took the code. Press and release the clear SAT button at the top left, and then you should be good to go.
If the TV never turns off during the code search, and the TV button at the top of the remote flashes a bunch of times everytime you press channel up, then there are no more remote codes. The remote does not have the code for your TV.
Hope this helps you.
Posted on Jan 06, 2009
I'm hooked up tp Dish Network an hit wrong button on top for volume and now pic is gone. in lower left corner says no signal., but dish is working, just no picture on screen
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to change your TV back to the proper input or channel. If the TV remote is not working to change the channels you can also use the buttons on the front of the TV. First look for a button listed as either input, TV/video, source or AUX. When you press this button it will start cycling through all the inputs available, make sure to cycle through them slowly because it make take a couple seconds for the picture to come in. If you do not find a picture on any of the inputs you are going to need to try the different channels. Normally for a TV where the receiver box is the TV should be set to channel 3 or 4. Once you have found your DISH Network picture you will want to make sure to push the SAT button on the DISH remote so that it doesn't change the TV channel again. I hope you find this information useful and if you have any further questions or concerns please let me know. Thanks. :)
Oct 22, 2011 | Craig CLC501 15 in. TV
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
Jul 14, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Logitech Harmony remote having trouble changing the channel
Harmony remotes use IR commands, so you will always have to have line of sight for it to work.
However, if you are using the RF extender, ensure that the device you are using to change channels is assigned to the extender, and that the extender is properly paired.
Feb 20, 2010 | Logitech Harmony Remote Control
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
DISH remote will not work for the first 10 minutes when the TV is turned on; so, I have to watch the channel I was watching before I turned the TV off. It seems to work fine after the initial 10 minutes.
Is the TV new? Is it a HD TV? If it is Either a 9Samsung LN(R/S)## Series , Sony Bravia/XBR# Series ,Sharp Aquos (New Models) , or Phillips ##PFL Series than the issue your haveing is what we call IR Remote Response Lost. its a light that cuts on and off that makes any IR remo not work some period of time. You have too call the TV manufactuer or use the manual for assistance. If you need details on how too fix it let me know!!!
Nov 01, 2009 | DISH Network IR Remote Control
Symphonic TV WF-13
I have had a problem like what you stated.
I turned TV off. Then unplugged the TV, for 5 mins.
Then plugged the TV back in the power outlet.
Also try the menu button on the TV itself, NOT the remote.
Scroll thru the menu button, with alt volumn & channel buttons
make changes.
Good Luck
JayHzg
Mar 30, 2008 | Televison & Video
Channels changing
What happens when you "hide" the remote from the TV so that the TV can't "see" it?...accordianman
Feb 29, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Broksonic CCVG297 9 in. TV/DVD Combo Logo
144 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
